1964 F100 towing capacity??? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-18-2014, 07:18 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
1963mercury Welcome to and th4e Slick60s Forum.
Why don't you talk him into delivering it? That is one hellava trip for an old dog.
John
Old 07-18-2014, 08:26 PM
tripleframe's Avatar
tripleframe tripleframe is offline
tripleframe is gaining momentum as a positive member of FTE.
If you asked a Ford salesman back in 1964, he would go to a data book and find this.
Old 07-19-2014, 07:06 PM
1963mercury 1963mercury is offline
1963mercury is starting off with a positive reputation.
John
It's gotta earn it's keep
Also, it's going to be an adventure on the way back w/ the airstream operationally & we'll take our time seeing some new vistas.
I'm going to look into some performance parts for the mileage maker. Also, contemplating bolting an overdrive system to the 3 speed.
Old 07-19-2014, 07:09 PM
Appreciate the picture. Just saw it after replying.
I guess it's too much trailer for the truck as I figure it weighs over 2,000lbs.
Rats...
Old 07-19-2014, 10:33 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
Moving it a few miles would probably be ok. Texas too Alberta! Wow. I towed a Dodge D150 behind mine on a car trailer for about 10 miles on back roads. That with the weight of the trailer was probably about 6000lbs. I have the 292 and a four speed with 3.89 gears. Pulling it up to speed was no issue at all. Stopping was a real PIA. Long planed braking and down shifting. Trailer brakes would have helped.
After about 10 years of pounding around with various F150s with 300/4.9 sixes I finaly realized that I need more truck. Coming in to the scales at 15k with a half ton pickup made people raise their eyebrows. The found it amazing that I used a six cyl engine to pull with too. I got tired of fighting sway and headwinds at 45 mph and winding out in third going up hills at 35 mph. I broke down and bought a massive gas pig F350 V10. Now I don't even have to worry about hills and wind and sway.............Just rather or not I will make it to the next gas station.
I do miss my old straight six four speed trucks. If I could find a nice 75-96 F250 or F350 set up like that I would get rid of this gas pig in a heartbeat. Problom is that all those types of trucks were sold to commercial and government users and ran in to the ground.
If you had a F350 I would say go for it. The big brakes and deep gears would probably work fine with a bit of effort up and down hills. But based on the bit of towing I have used my 64 for I would limit it to about 3500lbs or so and even at that number trailer brakes would be great. Your truck will move that camper. Just not stop it worth a shart and going up hills will take a long time in second gear.
Old 07-20-2014, 06:41 AM
jowilker's Avatar
Boss, We all have a right to be stoopid if we choose to be, you are talking about using a 50+ year old truck with the smallest engine available make a 2000 +/- trip one way through the hill country side of this continent, grab a travel trailer and drag it back home.
Why don't you rent a truck or van to make that long trip with? Once you have it home then take it out on a 50 mile camping trip until you get a better feel for what your truck is capable of doing.
John
stop light switch aaronsbicyclerepair 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-30-2015 06:21 PM
Newbie from Alabama irideblue10 New Member Introductions 1 03-23-2015 05:14 PM
Not the Death Wobble laurin 6.7L Power Stroke Diesel 4 01-04-2015 06:33 PM
C6 Tranny Specialist Sedalia plefe Missouri Chapter 6 01-03-2015 01:37 PM
1975 f100 with 390/need vacuum diagram peanut2001 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 02-25-2006 08:22 PM
Tags
1961, 1964, 1966, 1976, 64, capacity, capicity, f100, ford, hitch, pulling, tow, towing, truck, weight, what
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
