99 Explorer - Flashing O/D Off Light - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 03-15-2007, 05:07 PM
nikkiree nikkiree is offline
nikkiree is starting off with a positive reputation.
Last update:
Still get slip.
Still get O/D Off eventually.
No reverse.
Any advise? Dontate to charity?
Late,
Nick
  #62
Old 03-15-2007, 05:36 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to behold
does manual first gear work?
Matt
  #63
Old 03-15-2007, 05:37 PM
fordboy_52's Avatar
what im hearing is that there might be some dirt or trash in the valve body. this might be causing a valve to stick. let me look into it a little further
Matt
  #64
Old 03-16-2007, 03:34 PM
Manual 1st and 2nd gear work...When it goes into O/D Off, if I don't restart, I just manually shift through the gears.
Late,
Nick
  #65
Old 03-16-2007, 04:09 PM
fordboy_52's Avatar
this is just amazing me. i cant believe its all not back yet. did the mechanic use an inch pound and not a foot pound torque wrench
Matt
  #66
Old 03-16-2007, 04:11 PM
fordboy_52's Avatar
i have found other users on the internet having the same problems that corrected themselve relativly quickly
Matt
  #67
Old 03-20-2007, 05:24 PM
kokalo kokalo is offline
kokalo is starting off with a positive reputation.
O/D dosen't respond
Hello Guys
I have a Ford Explorer XLT 1999 with 54K miles on it. I bought it five years ago wit less than 14k miles. Problem that I have with my O/D is when I try to activate it on the shift gear it dose not respond. Light indicator is not showing that O/D is on or off. When I drive the car I do not see the difference from the time when O/D was functioning properly. I have noticed this problem today and it bothers me. Also I have noticed when I change my 4WD to the Low the light indicator wont turn on. It works for $WD high but not for low. Can this be a blown fuse or problem with the control panel display?
<OPlease help me.
Thank you.<O
  #68
Old 03-21-2007, 07:25 PM
O/d
I wuld really appriciate if sombady can give me som suggestion on my problem above.
Thank you,
  #69
Old 03-21-2007, 08:36 PM
fordboy_52's Avatar
man im not sure. could be a selenoid or something. im completly lost
Matt
  #70
fordboy_52's Avatar
whoops, double post.... sorry cobra
  #71
Old 03-21-2007, 09:44 PM
O/D dosen't respond
Thanks Matt,
Do you know how much will cost me to replace selenoids if that is the problem.
I went to AutoZone and they did code error scan and it turned to be just fine. The employee there suggested to check fuses and relays which i belive has nothing to do with this problem. I also checked for schematics on this car and it has no fuses for O/D and 4WD.
  #72
Old 03-21-2007, 10:00 PM
fordboy_52's Avatar
well the selenoids can be tested. we discussed this in the ranger forum. go look there
Matt
  #73
Old 03-23-2007, 01:42 PM
exlmtd exlmtd is offline
exlmtd is starting off with a positive reputation.
Would love to have the write up - totorial for de O/D problem.
thanks
edmartel@hotmail.com
Ed
  #74
Old 03-23-2007, 07:42 PM
fordboy_52's Avatar
its in the ranger tech forums now. scroll down and the links in the bottom
Matt
  #75
Old 03-25-2007, 04:30 PM
O/D Fixed
It was a stupid fix. I replaced a fuse and O/D started working. Stupid but inexpensive. Thanks all of you that tryed to help.
4R100 Trans OD light flashing, won't go into 4th, and occasionally over heats Slash19 1999 - 2003 7.3L Power Stroke Diesel 10 04-11-2016 04:15 PM
Odd shifting issues kameronth 1999 to 2016 Super Duty 23 05-27-2014 09:51 AM
99 Explorer Sport 4x4 Transmission Problems 99Explore4x4 Explorer, Sport Trac, Mountaineer & Aviator 11 11-12-2012 05:41 PM
OD Light Flashed a Couple of Times SLE Modular V10 (6.8l) 27 07-15-2011 06:47 AM
4r44e Trans problems 95 Ford Explorer mackmanj Clutch, Transmission, Differential, Axle & Transfer Case 0 12-20-2009 05:38 PM
Tags
1l5z7z490ga, 2l5z7c155aa, 3l5z7m203ja, 5r55e, ba, body, ford, gasket, kit, p0732, p0735, separator, service, solenoid, valve, xl2p7000, xl5p
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
