Question about torque converter plug
Not all our trucks have a convertor drain plug AFAIK. If it does, I would drain it at the same time and reuse the plug, it is a balanced unit, don't want to throw that off with a different mass plug. If it does not have a plug, just flush the system, costs more in fluid but why mix the new with the old?
Are you sure it doesn't mean replace as in put it back in?
Another thing to point out on my post is that I am the king of re-use. My boat motor manual calls for replacement of just about everything you touch whenever you touch it. If you even glance at it, replace gasket and bolts etc???? I could go broke doing that and have found most things can be re-used when assembled properly if they spec out. I have replaced only one oil pan plug gasket in all my years of wrenching if that tells you anything. I will not tolerate a leak but overkill is just that.
al0311
08-22-2015 08:58 PM
justcruzin125
07-06-2015 09:56 PM
csmrugby
05-28-2015 01:31 PM
plowboy2155
01-23-2004 04:47 PM
