Moisture in Crankcase??
Hey everyone, Ive done a search but nothing came up. I changed my oil today, at 40K miles. The filler cap had sludge collecting inside of it. I know that means there is water in my crankcase, but I'm pretty sure its not a head gasket. What could be causing this sludge buildup in such a young engine?
Thanks for the words in advance.
Leonard.
BTW I put a half can of SEAFOAM in the engine, maybe that will "dry it up".
2005 SCAB
5.4 L
Leonard.
2005 SCAB
5.4 L
mine does the same thing. I have a remote start to warm the truck and thanks to edge, I know my engine temp is at least 175 when I get to work. hot daily to spite the short trips and I still get condensation. I did a parts search and didn't find a pcv valve for this motor. am I right to assume it doesn't have one?
I wouldn't throw in any Seafoam in my crankcase. This is a kerosene type base cleaner. You may weaken your seals.
There is nothing unusual for a small amount of water to be seen on the oil filler cap. As others have said it is due to condensation and short trips not burning off the condensation. Ever see water come out of a tail pipe when stated cold?
If you are using your vehicle for short trips fololw the severe driving oil change interval in your owners manual.
I still think ths is normal, all the recent Ford trucks have a longer filler type neck where the mosture and condensation will accumilate. I recently looked at my 2004 again as well as my roomate's 2005 and two road deputy squads in the 4.6 and 5.4 and guess what? They all had some of the milky condensation underthe cap. I cannot believe all our engines are shot??
Wow, does the oil on the dipstick show water intrusion? There are other methods other than tearing it down to verify coolant leaks! Think this dealer is looking for some cash.
Do you have a Ford maintenance/warr extension plan, or an outside plan? Who pays if there is no issue found and it's been torn down! Bet it will be you!
I have to agree if it is only on the filler cap it's not an issue!
