Moisture in Crankcase??
considering the service dept's lack of commitment when it comes to covering it under warranty, I personally wouldn't let them touch it. you can see from these posts that its common in all these engines and I'd hate to see you get raped by a dealer just looking for some income. if there was a gasket issue you would have water show up on the dipstick, oil in the coolant, possible compression loss on 1 or more cylinders. an engine could exhibit any one or all of these symptoms when dealing with a head gasket issue.
just dropped my truck off for same issue, scared of head gasket or cracked head. they pressure checked coolant cylinders as a precaution. but said it was just condensation most likely. I had just completed a long run from jersey to NC within a couple days (1200 round trip), but my normal drive is about 5 miles each way, so its barely getting warm. I will be keeping an eye onit, but the more i think about it, i believe the condensation theory with the weird filler neck, just never seen it before. 25,000 here.
yea ... seems to be fine. the more that i look back, the fact that the oil on the dipstick was fine and that the coolant level never moved, i shoulda figure it out myself. Also, i got like 20 mpg going back and forth that trip, i would think it wouldnt be that good if something was wrong. Love the truck ... so i got a lil sceered i guess.
eallanboggs
2004 - 2008 F150
12-20-2021 06:09 PM
hozee4
21
12-21-2009 03:09 PM
Jordan Septo
37
03-04-2008 01:11 PM
