Foreign Object? Transmission Pan
I dropped the pan on my 05 F150 5.4 to change the transmission fluid. I found a plastic object that is shaped sort of like a top (a spinning top). The bottom is about 3/4" dia and has a "handle" 1" long. It has an o-ring on the bulbous portion. Any ideas as to what it is and do I need it? I looked for a place it would fit; there doesn't seem to be a hole that it would plug. It doesn't have any holes through it. I tried to see if it would fit in the bottom of the dipstick hole; however, it is too big.
I'm embarrassed to say it but I was low on fluid. It didn't reach the dip stick. I only got about 3.5 qts. out. I put 6 qts. which seemed to be just right. Yes there is a reusable gasket. It's a piece of cake. I went to Napa for the filter; $16ish "on sale". However, it wasn't the right one. I went to advanced (after my pan was dropped), they originally tried to give me the wrong one again $28 (similar to the napa one). When I called them on it, they said they couldn't get one for that model. So I went to Ford $33. Of coarse it worked.
Just an FYI Ford specs the 5.4 transmission fluid as lifetime. No change needed. So if you were down then you may have other problems to look for.
ENHANCED AUTOMATIC TRANSMISSIONS
Matched to the new 5.4-liter V-8 is a new 4R75E automatic transmission, an evolution of the 4R70E used on the current F-150. Upgraded to handle the torque of the 5.4-liter engine, this transmission shares patented upgrades with the 4R70E, which backs the 4.6-liter V-8:
- A redesigned torque converter improves launch performance and increases efficiency.
- A turbine speed sensor improves transmission control, providing the basis for fully electronic shift scheduling to limit "hunting" and to fine-tune shift speed and feel.
- Increased microprocessor speed improves responsiveness and precision of the control system.
- "Smart" fully electronic shift scheduling knows what the torque will be in the next gear so it chooses the shift points based on the vehicle's projected performance in the next gear.
- Coupled with the electronic throttle strategy, the transmission computes the output torque required to maintain the vehicle speed, and chooses the correct gear and converter state accordingly.
- A sealed case and lifetime transmission fluid make the transmission maintenance free, while adaptive pressure control maintains consistent shift feel over time.
I think my truck has a 4R70W transmission. That notion of life time fluid sounds like a bunch of BS to me. Of coarse that is just my opinion. If I'm not mistaken the service maintence schedule calls for transmission service every 30k miles. It is true that I read in the manual that the rear end is supposed to be maintenance free in most cases.
