How to Break in new F-150 - Ford Truck Enthusiasts Forums
Old 02-18-2007, 08:58 PM
mbogosia's Avatar
mbogosia mbogosia is offline
mbogosia needs to improve their reputation.
Hey guys. Just got home with my 2007 F-150 STX. I love this thing! Are there any sites with info on breaking our trucks in. Mine only has 32 miles and I plan on keeping it a long time so I want to do everything right.
Old 02-18-2007, 09:01 PM
gui88ford's Avatar
gui88ford gui88ford is offline
gui88ford is starting off with a positive reputation.
i'd be interested also...i'm getting a new one friday and i want to do it right also...
i'm sure the dealer will tell me some stuff but i find that the guys on sites are better...at least i think so anyway....sales guys don't know everything about the trucks so i found out it's better to go to the people that use them...
Old 02-18-2007, 09:08 PM
mbogosia's Avatar
Tell me about it. This guy was there 20yrs and he didn't no any of the details. I basically had to research everything. I guess they have so many trucks with different optioins its hard to tell what each has.
Old 02-18-2007, 09:18 PM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
Welcome to FTE mbogosia. What I can recommend, is to just make sure you vary your driving styles. What you don't want to do when new, is drive the thing at highway speeds for like 6 hours straight. Just make sure you drive over all sorts of road conditions and speeds. Slow driving... fast driving.... a few spirited accelerations... thats all you need. Certainly don't "baby" the truck on break in, but don't flog it either. As a rule of thumb, I have always had the dealer change the oil at 1500 miles. I know thats lower than the Ford recommended interval, but its worked quite well for me thus far. The way I see it, the motor has pretty well seated itself by then. The faster I can get any metal shavings out of the oil... the better. Enjoy the new truck!
Old 02-18-2007, 09:26 PM
mbogosia's Avatar
Yeah I figure there isn't much you can do. Drive it pretty much regular and don't beat on the brakes right away should let it break in pretty good. I need to go grab the manual and read it before bed tonight.
Old 02-18-2007, 09:37 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
What wheelma1 said.
I know on older engines they used to say, don't stay at any one speed for to long, don't go over a certain speed(for older engines it was 55MPH), and don't do heavy acceleration from a dead stop(do these things for the first 500 miles).
Other than that, I'm pretty sure new engines don't require quite as many things, just drive the way you drive, and it will break in the way you like it.
Old 02-18-2007, 09:57 PM
mbogosia's Avatar
Yeah, I just read the manual and that is all it says. I do have to drive from Nashville to Chattanooga on Tuesday which is about 200 miles. I have to make a stop in the middle though. I guess I'll try to vary my speeds during the trip from say 50-65mph mph.
Old 02-18-2007, 09:59 PM
WhlM1's Avatar
If there are any side roads you can take to "mix it up", that would be great to add into the journey.
Old 02-18-2007, 10:01 PM
never2big never2big is offline
never2big is starting off with a positive reputation.
Drive it like ya stole it...
Old 02-19-2007, 12:19 AM
is300wrx's Avatar
is300wrx is300wrx is offline
is300wrx is starting off with a positive reputation.
Congrats on your STX!! What i did with my STX for the first 1000 miles was that I made sure my truck would be warm before driving off. I kept the speed under 75mph and varied the RPMs. Good luck
Old 02-19-2007, 12:26 AM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Written a long long long time ago and referenced way back when by somebody on this board, had it saved ever since:
Quote:
I have posted it before and it always starts a opinion war but here are my ideas on "break in":
Many, Many, I say again M A N Y hot cold hot cycles are the best thing you can do for a new factory assembled motor. On start up try to teach yourself to get in, put in the key, turn to RUN and stop, put on seat belt while the computer boots, NOW turn the key to start, watch the lights and gauges and pay attention to the tachometer for a few seconds. The engine will settle back a few hundred RPM, NOW shift to drive and again pause a little with the brakes on. Release the parking brake (you do ALWAYS use the parking brake don't you).
Now spend some time training yourself to NOT turn the steering wheel UNLESS the truck is rolling. I trained myself this technique of steering many years ago and my front ends last years beyond what "normal people" get before ball joints and wheels bearings need replacing. Turning a power steering lock to lock while the vehicle is halted is a BAD thing teach yourself to NEVER do it! Same goes for turning all the way to the steering limit stops. Never ever continue to keep turning the wheel once the mechaincal stop is hit, in fact TRAIN yourself to ALWAYS back off a tad when you hear/feel the limit stop.
OK, Lets BED the brakes. You should do this emmediatly as you leave the dealer, in fact I do a lot of it in his lot (my dealers lot is big enough). Get up to 30mph and when safe do a very hard (not lockup or ABS starting) but very hard braking just shy of a full stop, as you feel the truck about to halt, let off and smoothly accelerate back to 25, 30 mph. Repeat this 4 or 5 times while looking for a clear parking lot or unused back road. Let about 3 or more minutes pass between hard braking series to let the rotors settle to the new temp. Do this in a place where you do NOT have to come to any complete stops with the brakes while the rotors are hot! We are deliberatly trying to get the rotors VERY hot.
Once you have a SAFE place to do some more of this, do another hard brake series and get out of it while still rolling as before, but this time just coast to a normal stop. Clear your rear and shift to reverse and get up to a fair clip and do a hard brake in reverse, but again NOT to a complete stop. Do this several times as far to the rear as you can in the selected place but try very hard to NOT bring the truck to a complete stop with the brakes pads holding the very hot rotor.
What we are doing here is "burnishing" the pads, and forcing very controlled and even heating to the rotors and attaching assemblys. There NO such thing as WARPED rotors... BUT there is a condition called material trasnsfer, caused by superheated PADs that leave some of their material on the rotor and causing them to pulsate due to the uneven surface.
For the first few days try to set up your stopping to NEVER bring you to a full stop with the pads HARD clamped to hot rotors. This is hard to do and do not ever forget safety for you and others. If you must bring the monster to a quick and complete stop as soon as you are stopped ease up on the brakes and try to creep if there is room.
Most of the first several days I try to set up stop lights so I have a good buffer between me and cars ahead, I brake fairly aggresivley and with a two car buffer ease up and roll out until one car buffer then slowly creep up to the car in front. Usually the light changes before I need to full stop. Not always but this method lets some cooling and no pad to rotor in fixed spot. Do this a couple of times during the first 100 miles and your brake pads and rotors will last a long time and stopping power will be greatly enhanced.
Do not be tempted to try and break in over a weekend with some sort of long trip just to build miles. The setting of the rings can be done in less than 500 miles and takes patientce. I must re-state Many, Many hot cold cycles are much better.
For the first 500 miles try to do town type driving. It is OK to be a little hot on the take off. Just refrain from spending ANY time at RPM above 3500 or below 1500 under load (lugging the motor). Deliberatly do trips "to the store" where you get her up to full operating temp and while "shopping" she will cool off. Do a LOT of frequent shopping. Don't get everything at the one Lowes or Autozone "in town". Cruise accross town to a buddies house, drink a beer while he is admiring you new ride. Think safety and drink a soda or two for another hour or so while the engine cools and you detox. Repeat for as many buddies as you have. Watch the drinking and driving, your truck can not give you enjoyment from a jail cell.
At least once every driving cycle and after fully up to operating temp, do one good strong take off from stop up to 3500rpm and throttle shift the 5R110 auto tranny. Throttle shifting is when you use enough foot to run the rpms to where you want them then lightly let up and feel the auto shift up, get back firmly on the foot until RPMs are back and continue this through the gears. Practice this with another vehicle to get the feel. After the 500 mile mark do not be afraid to do this up to 4200rpm on occasion. But try to never spin the motor past 3500 unless it is under power and emmediatly falls off back to lower rpm.
Cruise control is forbiden the first 500 miles! For the next 500 only occasionally to learn how it works and feels. After 1000 you can use it when ever you want.
At 500 miles replace the Factory Motorcraft FL820 and 5w20 with same and enjoy the next 500 miles increasing the drive cycles and shortening the cool cycles. I change oil at 1000 also but admit it is overkill, I just dig doing it and LOGGING it because the rest of the trucks life some other monkey is going to change my oil while I watch.
Every chance you get, pull into a large parking lot and AWAY from every body spend some time in reverse, and straight line 4x4 hi and low. Do NOT turn the truck while in 4X4 on dry ground, just straight forward and reverse.
All my Ford Gasoline motors always take 5 to 8 thousand miles to "break in" where the MPGs get best. Don't even start to be concerned with low mpg figures until she is fully loosened up. With a auto trans, transfer case, 4x4, big rear end, and lots of engine this takes time, be patient.
Train your self to always shut off the radio and heater/AC as part of your normal daily shut down procedures. Periodically change the heater and AC controls to "exercise" the various dampers and doors and modes. If you do this as an **** psychotic obsessive compulsive daily routine then the vacuume actuators will always work.
If you are like me and plan to wear out the factory tires before you switch to better ones consider rotating in the X pattern at the 500 and 1000 mile oil change. After that rotate X pattern evey normal oil change. The X pattern tire rotation puts a left front tire spinning forward on the right rear where it will now spin backwards. This pattern should only be done on NEW radial tires and not ever done on radial tires driven exclusivly in one direction since new and only rotated front to rear same side. Tires break in also and how you start it is how you should continue for life of the tire. Fords spare tires are always on el-cheapo steel wheels and I don't bother to get the spare into the rotation mix. UGLY!
Squeaky breaks while in reverse Mikes150 2009 - 2014 F150 8 07-22-2015 10:33 AM
breaks FordRun 1987 - 1996 F150 & Larger F-Series Trucks 1 04-13-2015 01:30 AM
break problem kyle19895.0 1987 - 1996 F150 & Larger F-Series Trucks 12 02-16-2015 09:37 PM
1986 f1504.9 inline 6 break booster bidding at me help please respectedtech86 User Gallery & Picture Display 0 07-02-2014 10:41 PM
How do I remove the Cowl and Bedside emblems without breaking them? Ken2600 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-01-2002 02:42 PM
Tags
150, break, breaking, f150, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
