86 ford 302 FI Fuel Pump Relay
Old 02-18-2007, 07:23 PM
MikeFlorida's Avatar
MikeFlorida
MikeFlorida is offline
Question 86 ford 302 FI Fuel Pump Relay
Can someone tell me where the fuel pump impact cutoff switch is located on a 86 ford 150 4x4. I looked in the passenger floor board but did not see one. The previous owners of the truck i got have the high pressure fuel pump wired to the red wire on the relay. This wire gets hot when the key is turned on but there is no power going to the in tank fuel pump. I know the pump is good as it will run if I send power to it from a wire at the relay. Are these pumps designed to run all the whole time the key is on or should they be shutting on & off?
Thanks,
Mike
Old 02-18-2007, 07:44 PM
77monster's Avatar
77monster
77monster is offline
it should be there at the passenger side kick pannel at the top of it kind of behind it just feel around you should find it
Old 02-18-2007, 08:15 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
When the key is first turned, the relay turns the pump on for a few seconds to prime the system. If the engine starts, the computer verfies the engine is running by looking at the signals from the distributor module. If the engine is running, the computer keeps the relay pulled in, and the pump runs all the time.
This brings up a good point. It's not good for the pump to run very low fuel levels in the gas tank. The gas in the tank helps cool the pump.
The pump does not build up a lot of pressure and dead head. There is a regulator on the fuel rail that goes to the injectors. It has a return to the tank fuel line it controls. It keeps the pressure at around 40 lbs. If the pressure tries to get above 40, it directs some of the fuel back to the tank through the return line.
Old 02-19-2007, 12:32 PM
85lebaront2's Avatar
85lebaront2
85lebaront2 is offline
Old School Hot Rodder
I believe on the 86 models the inertia switch is on the heater duct on the right side of center. That's where my 86's switch is. Do you only have the one tank or two? Unfortunately, my EVTM is loaned to a friend who just bought an 86 truck and is trying to sort out some electrical gremlins of his own.
Old 02-19-2007, 09:09 PM
MikeFlorida
I found the switch today and it is working properly. Has continuity when closed and none when opened. I still cannot get my fuel pump to run without straight wiring it.
There are 4 wires going to my relay:
Pin #1 Tan/grn wire---Get power from Pin #2 when key is on.
Pin #2 Red Wire---Hot when key is ON
Pin #3 Brown wire-- NEVER gets power through the relay, But pump will run if I send power to it from the yellow wire or Pin #2 red wire with key on.
Pin#4 Yellow wire -----Hot All the time even with key OFF
I was having a problem with my original relay that when I hooked up power to the battery the pump would run. I changed relays and now the pump will not run. I went back to the parts store tonight and swapped relays to one that has 5 pins , but basically the same wiring diagram on top & it still will not work. Pin #3 & #4 should connect when the switch closes, but the switch is not making. What closes the switch? I tried to show the diagram that is on the relay below. What else can I do? Any Ideas?
3 ------/ -------4
1 ----
r
e
s On the relay this is represented as a curly cue line between 1 & 2
i
t
o
r
2 ---
Old 02-20-2007, 05:25 AM
85lebaront2
I have run into a problem with some of the aftermarket relays on Fords. The PN should be: F8PZ-14N135-BA this number was obtained from Wynne Ford, Hampton Virginia on October 30th 2006
Old 02-20-2007, 09:10 PM
MikeFlorida
Thanks for the tips...I have narrowed it down to the wire going from the relay to the computer under the dash is not geting a ground. I traced the wire from the fuel pump all the way to the computer and it ohms out good. I can connect the wire to ground and the pump goes on and off with the key. Would it be a problem leaving the wire grounded. The control power goes on and off with the key. Thanks for any advice.
Mike
Old 02-21-2007, 09:27 AM
85lebaront2
The ECM is supposed to ground the relay for a few seconds on power up, then ground it during cranking and with the engine running. It gets its engine running signal from the distributor. If you leave it grounded, it will work, but you loose the fuel shut-off if the engine stalls. One of the issues I have run into on these is the ECM ground, it is near the battery on 86 trucks, a bad or missing conection will drive you bats. Once my EVTM manual returns, I will scan the appropriate pages and post them on my website for all to see.
crandallf150
12-03-2016 08:48 PM
drsinisterr69
1997 - 2003 F150
03-11-2016 07:02 PM
Rhino99
Modular V10 (6.8l)
02-21-2016 06:11 PM
skalrim1134
1978 - 1996 Big Bronco
12-24-2010 02:30 AM
Bayer-Z28
General Automotive Discussion
03-21-2010 01:08 PM
Quick Reply: 86 ford 302 FI Fuel Pump Relay
