Toe-in
Whatever the original spec was, you probably don't want to use it. It was for bias-ply tires, and if you are running radials that spec will scrub off a lot of rubber unnecessarily. I don't recall ever seeing toe-in in degrees, it is usually in distance (inches or mm). As I recall for a beam axle with radials, the proper spec is 1/16" toe-in.
Have your alignment shop switch the equipment to read "toe" in inches, then you can work from the factory specs as a starting point. As ALBUQ F-1 stated, 1/16" toe-in is a good starting point. If you find it wanders on a straight, flat road then the toe-in probably needs to be increased.
Lou
Lou
02GrayPowerStroke
1997 - 2003 F150
11-26-2016 07:51 AM
