Is here a thing of 351 HO? - Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: SideWinder4.9l
Old 02-17-2007, 08:03 PM
cmaupin's Avatar
cmaupin cmaupin is offline
cmaupin is starting off with a positive reputation.
Exclamation Is here a thing of 351 HO?
I am looking in buying a 1986 F150, to replace my 81 f100 both are 4x4. The guy said that the motor is a 351 HO. I have looked and looked and have not found anything that says there is a 351 ho in pick-ups. Some in the police cars. My question is if the motor is a 351 HO, is it a cleveland or winsor ? Thanks
Charles
Old 02-18-2007, 01:54 PM
Bobs55effie's Avatar
Bobs55effie Bobs55effie is offline
Bobs55effie is starting off with a positive reputation.
Quote:
Charles
Ifyou can't get your answer here, you may want to check with sbftech.com There are some really good engine guys over there.
Good Luck!
Old 02-18-2007, 10:20 PM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
I had one that was swapped into a work van. It's a Windsor engine if I remember correctly
Old 02-19-2007, 05:29 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
Yes they are a windsor engine and yes they did come in trucks. I have seen them in some of the broncos.
Old 02-20-2007, 05:07 PM
Bluehawk Bluehawk is offline
Bluehawk is starting off with a positive reputation.
I had an '85 Bronco with a 351 HO engine. It was a 351 Winsor, not sure what made it the HO, but that is what the air cleaner cover said. It is not an easy motor to find.
Bluehawk
Old 03-22-2007, 01:02 PM
harold morgan harold morgan is offline
harold morgan is starting off with a positive reputation.
check your vin # for a Y to verify it an HO.
Old 03-23-2007, 09:33 PM
79_effie's Avatar
79_effie 79_effie is offline
79_effie is gaining momentum as a positive member of FTE.
If I'm not mistaken, the HO had a 4 barrel carb whereas the standard 351 had a 2 barrel. If there were any other differences I'm not sure.
Old 03-23-2007, 11:35 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It had a 4bbl Holley carb and a marine camshaft. I've seen them in 85-87 trucks. The air cleaner says 351 4V HO
Old 05-16-2007, 08:41 PM
uriah's Avatar
uriah uriah is offline
uriah is starting off with a positive reputation.
Yep, 351W with a Holley and different cam.
Old 05-21-2007, 02:11 AM
4starcstms 4starcstms is offline
4starcstms is starting off with a positive reputation.
Roller cam wasnt it??/
Old 05-21-2007, 10:13 AM
rywegh's Avatar
rywegh rywegh is offline
rywegh has a good reputation on FTE.rywegh has a good reputation on FTE.
Quote:
Thats what I was getting ready to suggest as I recall reading something about the rollercam also.
Old 05-21-2007, 03:11 PM
im 99% sure the 302 HO's were roller motors, I dont see why the 351's were'nt. Keep that in mind when shopping for cams and engine parts.
Old 05-22-2007, 07:24 AM
LxMan1's Avatar
No it was not a roller, those didn't appear until the mid 90's. It is a standard flat tappet hydraulic cam with more lift and duration than the standard 351W. It is actually a torque building cam that was designed for boat engines IE: marine cam.
Do the 302 and 351w have the same Bellhousing and Motor mounts? cbr3 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 02-14-2012 07:19 PM
1984 F150 351W HO corner27 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-22-2010 11:27 PM
351HO Identification/Pictures hansol04 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-04-2010 01:27 PM
84 351 HO used in 91 F250 furz4 1987 - 1996 F150 & Larger F-Series Trucks 2 02-06-2004 12:35 PM
351Ho hp & tq 85351ho 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 02-22-2000 04:29 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1987, 351, 351ho, 351w, barrel, cam, engines, ford, ho, lift, marine, mod, reviews, truck, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
