97 PSD will not start after installing superchip
Old 02-15-2007, 06:58 PM
Bloodline_F250's Avatar
Bloodline_F250
Bloodline_F250 is offline
Cool 97 PSD will not start after installing superchip
I just installed the superchip and now the truck will not start. I tried disconnecting the battery terminals for 30 mins that didn't work. Check the fuses they are good. The wait the start light doesnt come on at all. Tried to hook back up the superchip to turn it back to stock and that didnt work either. Running out of ideas.
Old 02-15-2007, 08:18 PM
ltfox's Avatar
ltfox
ltfox is offline
Check your fuses. Under hood fuses also. (#22)
Old 02-15-2007, 09:11 PM
Bloodline_F250
what is the #22 fuse?
Old 02-15-2007, 09:16 PM
ltfox's Avatar
ltfox
ltfox is offline
It powers a few things including the power to the pcm.
Old 02-15-2007, 09:17 PM
ltfox's Avatar
ltfox
ltfox is offline
Are you getting a error message from the tuner?? Might have to call superchips and talk to them.
Old 02-15-2007, 09:36 PM
Bloodline_F250
Yea I was going to call them tomorrow. But I get an error message on the tuner saying that it cant connect to the engines computer.
Old 02-16-2007, 07:08 AM
14psd's Avatar
14psd
14psd is offline
Bloodline call superchip. I had a similar problem last fall. Scared the you know what out of me cuz I put the program back in, out on a job site and got an error message. They were very helpful. I had to deprogram truck and send programmer back due to error in programming on superchips part. They took care of me very quickly.....It sucks to have to drive in stock program when you're use to hi po.
Old 02-16-2007, 07:40 AM
Bloodline_F250
well i check the #22 fuse and it was blown got another fuse and it blew. Whenever the key is in the on position the wait to start light comes on then goes out because the fuse keeps blowning
Old 02-16-2007, 08:59 AM
BEECHBM69's Avatar
BEECHBM69
BEECHBM69 is offline
Your fuel heater is probably (hopefully) shorting out against the side of the filter canister. Someone correct me if I'm wrong but I think its the middle connector on the drivers side of the fuel canister. Unplug it and replace the fuse and see if it blows.
Dan
Old 02-16-2007, 09:05 AM
rockyrider's Avatar
rockyrider
rockyrider is offline
Yes, 2nd plug from top,driver side of fuel bowl. Red wire with green tracer, small spade plug. Unplug and replace 30amp fuse (#22) and see what she says.
Old 02-16-2007, 09:44 AM
ltfox's Avatar
ltfox
ltfox is offline
Unplug your fuel heater and ya should be good. Check out the other thread on #22 fuse also for tips.
Old 02-16-2007, 07:54 PM
Bloodline_F250
but why would it just blow out of no where?
Old 02-16-2007, 11:21 PM
ltfox's Avatar
ltfox
ltfox is offline
Your heater inside your fliter canister shorted out. Its a common problem with these trucks.
Old 02-17-2007, 05:19 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
You can leave it unplugged. Mines been disconnected for a few years.
Here's more info on fuse #22.
https://www.ford-trucks.com/forums/5...fuse-22-a.html
Old 02-17-2007, 03:55 PM
Bloodline_F250
will i have still have heat. ill do it on monday on my day off.
Quick Reply: 97 PSD will not start after installing superchip
