Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 02-15-2007, 05:43 PM
tom18287 tom18287 is offline
Garage is empty, add now
tom18287 is starting off with a positive reputation.
Windshield wipers don't work.
01 f150 supercrew
well, i was cleaning off my windsheild yesterday, and they worked fine. this morning i discovered my windshiled wipers don't work anymore. they move freely together at once(if i move once, they both move) and if have them like 3/4s of the way up they will catch and move a little bit then stop again. i found this a little while ago:
2001 FORD F150 VISIBILITY:WINDSHIELD WIPER/WASHER:MOTOR
Recall Date: 08/08/2001
Summary:
VEHICLE DESCRIPTION: PASSENGER CARS, SPORT UTILITY VEHICLES, AND LIGHT AND MEDIUM DUTY PICKUP TRUCKS. A SWITCH LOCATED IN THE PLASTIC COVER OF THE WIPER MOTOR GEAR CASE COULD MALFUNCTION AND OVERHEAT, POTENTIALLY RESULTING IN LOSS OF INTERMITTENT WIPER FUNCTION, LOSS OF WIPER PARK FUNCTION, COMPLETE LOSS OF WIPER FUNCTION, OR IGNITION OF THE PLASTIC COVER MATERIAL. SWITCH MALFUNCTION IS MOST LIKELY TO OCCUR WHEN THE INTERMITTENT SETTING OF THE WIPERS IS BEING USED, OR WHEN SNOW OR ICE OBSTRUCTS THE BLADES FROM RETURNING TO THE "PARKED" POSITION AT THE BOTTOM OF THE WINDSHIELD. THESE VEHICLES WERE BUILT AT THE FOLLOWING ASSEMBLY PLANTS: ATLANTA PLANT FROM 2/11/00 THROUGH 7/31/00; CHICAGO PLANT FROM 2/14/00 THROUGH 8/4/00; KANSAS CITY PLANT FROM 2/26/00 TO 9/4/00; KENTUCKY TRUCK PLANT FROM 2/18/00 TO 8/31/00; MICHIGAN TRUCK PLANT FROM 2/23/00 THROUGH 8/3/00; NORFOLK PLANT FROM 2/21/00 THROUGH 7/27/00; WAYNE STAMPING AND ASSEMBLY PLANT FROM 2/25/00 THROUGH 8/15/00; AND WIXOM PLANT FROM 2/15/00 THROUGH 8/8/00.
Consequence:
LOSS OF VISIBILITY WHILE DRIVING INCREASES THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSPECT THE DATE CODE ON THE WIPER MOTOR. MOTORS BUILT WITH THE SUSPECT TIME FRAME WILL HAVE THE WIPER MOTOR GEAR CASE COVER REPLACED. OWNER NOTIFICATION BEGAN AUGUST 20, 2001. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-866-436-7332.
Potential Units Affected: 1083000
Notes: FORD F150 01S24
but my truck isn;t in those recall dates, but that description fits it to a tee. with all the ice(i live in MA) building up, they weren;t returning "home" like they were supposed to. is it an easy fix? is it expensive? should i call ford and see if my truck is in the recall, even though when i search the vin it comes up negative.
i dont know,
thanks,
tom.
  #2 (permalink)
Old 02-15-2007, 06:36 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
It's a problem with the design of the overall system.
The arms can freeze in ice and still break gears and the like.
Make sure everything is clean before you use them.
Down under the trim can also get frozen and make everything bins up.
The wiper motor dosn't know this and still tries to move the whole assembly.
Same with power windows. Don't try to move them until the cab is fully warmed if they are frozen fast at the window wipes.
  #3 (permalink)
Old 02-15-2007, 06:51 PM
jimm66's Avatar
jimm66 jimm66 is offline
jimm66 is starting off with a positive reputation.
Just saw a post recently where wipers didn't work. They were froze and if you force them it strips the knurled post that the arm is attached to. Take off both wiper arms and see if they are turning. The short fix was a little aluminum foil over post then tighten down arms. Maybe!
__________________
2002 F-150 XLT supercab FX4 5.4, true blue, Westin oval bars, lo-pro, piaa horns, rancho 5k's,
husky liner mud guards, trail-seal, sirius, fire extinguisher, mag-lite, tail-gate-easy-lift, bfg at ko's, custom si-do pipes, mag. 18 " & mag tips,
garmin 660, wet-okole seat covers, putco bed rails, bed-rug, recon 3rd. brake lite, led hitch cover. kenwood-mp242 hu, pioneer speakers,
  #4 (permalink)
Old 02-15-2007, 08:35 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to the forum Tom
If you can move the wipers by hand then the problem isn't in the motor and the recall won't do you any good.
What's probably happened is the plastic socket on the wiper linkage, where it attaches to the pivot on the motor, is worn and fell off. From Ford you can't get just the socket, you have to buy the whole linkage assembly. I believe that there may be some aftermarket sources for the socket. I would check with local parts stores.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #5 (permalink)
Old 02-16-2007, 05:50 PM
54fever 54fever is offline
54fever is starting off with a positive reputation.
I just had a my wipers break on me, same thing, i turned on my wipers and there was ice on the cowl (dumb thing to do) and the wiper arm caught the ice and well, that was the end of that. The wipers only moved about an 1" to 2" so i took it to the dealer and the mech said the wiper transmission was bad and will cost me $430.00 bucks to fix. motor and trans all one unit, so how hard would it be to replace it myself. Its a 98 f-150
  #6 (permalink)
Old 02-16-2007, 06:21 PM
rsylvstr rsylvstr is offline
rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.
Quote:
STOP!!! don't buy the socket or whatever....use Jimm66's recommendation first...I did this to my 2001 F150 and haven't had a problem since!
no need to take off the black cowl or anything, just pull the cap off each arm, take the nut off (or just try to tighten first) and then throw the Al foil on it...then tighten the nut, install the cap and test.
__________________
Master Chief, HMCM(FMF/AW)
JOIN US http://www.nyfirearms.com/forums/ind...eferrerid=1780
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
  #7 (permalink)
Old 02-16-2007, 08:45 PM
but the thing is, it's not those, because when i move one, both of them move still, so it must be the transmission, however it still turns on, so i wonder if someting just came undone.
  #8 (permalink)
Old 02-18-2007, 08:54 PM
ecship ecship is offline
ecship is starting off with a positive reputation.
Quote:
I just had to replace the wiper motor for my '02 XL today.. I started the truck, let it warm up fully, cleared all the snow/ice from the windshield/cowl area, then,since the windshield was dirty figured I would run the washer to clear the glass.. the wipers went about 1 1/2 strokes and just quit. wiggled the driver side arm slightly, started to move and made an awful grinding noise. figured the gear in the transmission stripped, so I took the cowl cover off to take a look. the entire cowl vent area (where the wiper assembly hides) was a big block of ice (we had an ice storm here in MA, and I was away on business all week) the motor wasn't too hard to change. but it was a little bit of a trick to get the assembly out. first after removing all of the plastic covers over the cowl vent, I had to power the wipers on and shut the key off at the high point of the stroke so the linkages would clear the cowl. the other trick I found out was that the assembly would not come out with the hood closed or in it's normal open position, so I had to remove the ball sockets off the gas shocks and over extend the hood (basically it was straight up at a 90 degree angle from the truck) then a was able to get the assembly out in one piece and swap the motor out on the bench. wasn't really hard, just time consuming. (the remanufactured wiper motor cost me $53 at CAP)
  #9 (permalink)
Old 02-18-2007, 09:12 PM
for this one, i'd surely try the foil trick....mine would "jump" an inch or two...so i fixed it using the foil method.
__________________
  #10 (permalink)
Old 02-20-2007, 06:18 PM
ecship, samething here in NJ had an ice storm, i just bought a used complete unit with linkage and all from a salvage co. off ebay. the unit is supposed to only have 76,000 miles on it and has a 30 day warranty and as for the dealer wanting to charge me 430 bucks to do the job i think i will be able to do it myself. Thanks for your input on my problem.
Ernie
Tags
2001, 2002, arm, dont, f150, f250, fix, ford, lariat, lightning, tighten, windshield, wiper, wipers, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
