Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 02-15-2007, 09:52 AM
alberta46 alberta46 is offline
Garage is empty, add now
alberta46 is starting off with a positive reputation.
possible u joints?
Hello all got no answer from the axle etc forum. 97 f150 4x4 ext cab. here is my problem with all the snow recently the roads here are quite uneven and rough.Since then my truck has developed a clunking noise not all the time but seems when the truck is moving on an uneven surface. On clear pavement it does not seem to happen yet. very irregular pattern. I have not noticed any vibration at highway speeds. Could this be u-joints? I crawled under the truck with it parked in gear and tried to move the driveshaft and there seems to be a small amount of play in it. Am I going in the right direction? also I had someone in the rear seat and when the clunk happened he said he could feel it under his feet that would put it about right for the front u joint I think? sorry for the long post. any help would be appreciated.
  #2 (permalink)
Old 02-15-2007, 09:55 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
ah the infamous driveshaft "clunk"
That's been around for years.
What I do is stuff some hightemp sticky grease inside the yoke receiver.
This seems to take the clunk out.
  #3 (permalink)
Old 02-15-2007, 10:02 AM
thanks for the reply million but it doesnt seem like that kind of a problem. it only happens when the truck goes uneven for lack of a better word its real hard to explain. Say if your front end is going up a hill and the rear is going down like a driveway or when the front leans to the right while the rear is to the left. Hope that explains a little better
  #4 (permalink)
Old 02-15-2007, 10:39 AM
RobInAB RobInAB is offline
RobInAB is starting off with a positive reputation.
Is it a single clunk or one that correspondes to a spinning driveshaft? That would narrow it down quite a bit
While underneath, you could check for shiny metal spots indicating where something is hitting or rubbing.
  #5 (permalink)
Old 02-15-2007, 10:44 AM
single clunk. then be ok for a bit then one no real pattern to it
  #6 (permalink)
Old 02-15-2007, 10:45 AM
Also it will happen wether under load or with truck out of gear (its a standard).
  #7 (permalink)
Old 02-15-2007, 10:51 AM
Doesnt sound like a driveshaft/u-joint issue to me. Sounds more like a loose suspension componenet somewhere issue.
  #8 (permalink)
Old 02-15-2007, 02:33 PM
Thanks all for your help. I found it! stabilizer bar mount where it mounts to the lower control arm was broken 37.00 and a pair of wet jeans from laying in the snow and im ready to go!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
