Will 32/11.50/15's fit? I have a 92 Bronco with a small body lift maybe an inch I am needing to replace my dunlop mud rovers currently 31/10.50/15's will a larger size fit. If so I am gonna go with them.
With a little lift no prob. I have 32 11.5 BFG MTs just needed to trim an inch off the lower inside corner of the bumper. You will only need to do that if they rub there when you turn real hard.
I have them in the BFG AT format and they work fine - I THINK its had a bit of a lift to level it out by the previous owner but it can't be much if any. Bumper is stock position.
They look good but can be a bit twitchy in the wet as they are so wide - very easy to get the back end out when you least expect it.
