lower ball joint - Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
lower ball joint
Old 02-13-2007, 07:15 PM
1989 Ford F-150 1989 Ford F-150 is offline
1989 Ford F-150 is starting off with a positive reputation.
Question lower ball joint
hey anyone know how 2 get this thing out of the lower a arm? what tools required and anyone close to help
Old 02-13-2007, 07:57 PM
DetailerDave's Avatar
DetailerDave DetailerDave is offline
DetailerDave is starting off with a positive reputation.
Most likely, just guessing, it is pressed in. Where you located?
Old 02-13-2007, 08:10 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
according to the service manual, remove the spindle and ball joint assembly from the axle.
mount the spindle assembly in a vise and remove the snap ring from the lower ball joint remove the lower ball joint from the spindle using tool T74P-4635-C C-frame, and receiver cup D81T-3010-A4
from the pictures in the manual, it almost looks something like a big C clamp with a cup on the solid side for the ball joint to be pressed out into.
i have never done a 4X2, so this is about all the help i can give you.
Old 02-14-2007, 03:20 PM
frederic's Avatar
frederic frederic is offline
frederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to allfrederic is a name known to all
That's how it's done. Done it myself, and it required a lot of beating with a wooden mallot.
Eat your wheaties beforehand. It's an unpleasant job.
Old 02-14-2007, 09:27 PM
located 3 miles from atco raceway
lower radiator rub daybo13 2009 - 2014 F150 1 11-30-2014 07:23 AM
Who's lowered? HotRodEconomist 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 09-11-2014 06:12 PM
Lower grille automaticj5 1999 to 2016 Super Duty 4 11-07-2013 06:24 PM
1988 f150 2wd lowering kit????? 1982_f150 1987 - 1996 F150 & Larger F-Series Trucks 2 07-06-2007 08:31 PM
Lowering 59 F100 shipfitter1966 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 06-16-2006 04:38 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
04, 4635c, assembly, ball, cup, f150, ford, frame, joint, lower, pic, picture, receiver, t74p, t74p4635c, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
