Why does my exhaust smell so bad? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 11-17-2002, 06:29 PM
BroncoScott BroncoScott is offline
BroncoScott is starting off with a positive reputation.
I have been told a bad O2 sensor can cause it. Any ideas?
'89 302 AOD Bronco, Grant wheel, junk '31 tires for now,JVC remote CD
Old 11-17-2002, 06:42 PM
MadDAWG MadDAWG is offline
MadDAWG is starting off with a positive reputation.
what does it smell like? If it smells like gas then it could be a bad O2.
Old 11-17-2002, 06:53 PM
Sulfer, rotten eggs
'89 302 AOD Bronco, Grant wheel, junk '31 tires for now,JVC remote CD,
restorit's Avatar
restorit restorit is offline
restorit is starting off with a positive reputation.
More than likely, it is. When the O2 sensor goes, typically, your computer will default to a richer than normal mixture to prevent damage to the engine from a mixture that may be too lean. As a result, you'll get a rotten egg smell as the richer exhaust passes through the catalytic converter.
Old 11-17-2002, 07:01 PM
Can it be bad without being out of range enough to throw a code? My closed loop performance really is poor also.
Old 11-18-2002, 02:23 PM
sideout2 sideout2 is offline
sideout2 is starting off with a positive reputation.
A rotten egg smell is usually a bad Catalytic converter.
Old 11-18-2002, 07:30 PM
I thought they just get plugged up when they don't work.
Old 11-19-2002, 10:10 AM
[updated:LAST EDITED ON 19-Nov-02 AT 10:12 AM (EST)]They do get plugged, but also can go "bad" as it can no longer perform properly and a rotten egg smell is one of the first signs. A bad O2 sensor can cause a funky smell, but that is from the sensor causing the engine to run rich. The smell will be more fuel like(for lack of a better work)
Old 11-19-2002, 11:09 AM
gruveb gruveb is offline
gruveb is starting off with a positive reputation.
Something you ate?
Feeding my 9 mile a gallon habit.
Old 11-19-2002, 02:16 PM
hillbillyk hillbillyk is offline
hillbillyk is starting off with a positive reputation.
rotten egg smell, bad catalytic converter
Old 11-20-2002, 05:28 PM
mweeps mweeps is offline
mweeps is starting off with a positive reputation.
Exhaust never smells good. But rotten egg sulfur smell has to be killer. Hope you have a strong stomach until you get it fixed. if it is Cat get a Bassani high flow cat to replace it since you are going to have to replace it.
Old 11-20-2002, 05:30 PM
What Steering Wheel? twozzie 1973 - 1979 F-100 & Larger F-Series Trucks 24 09-27-2016 08:14 AM
Neb.Auction firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-16-2014 02:22 PM
Barry Grant Carb 68cabby Ford Inline Six, 200, 250, 4.9L / 300 7 05-05-2014 10:58 PM
whre to buy steering wheel for 69 centralNH 1967 - 1972 F-100 & Larger F-Series Trucks 6 03-13-2014 03:24 PM
Motor Choices For A 1962 F100 Flareside. 1962F100dude 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-13-2013 03:21 PM
Tags
1999, 351, bad, egg, eggs, exhaust, f150, ford, o2, odor, rotten, saensor, smell, smells, sulfur
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
