Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 02-13-2007, 08:54 AM
F-250 diesel F-250 diesel is offline
Garage is empty, add now
F-250 diesel is starting off with a positive reputation.
how much oil does it hold??
ok....i know its been discussed before.....well probably
but i would like to hear from you guys.
in my manual, it says the 5.4 holds 6 quarts of oil, at work, i went on AllData and it says it holds 6.6. Whenever i changed my dads oil i always put 6 qts in and it was always at the half mark. So when i changed his and mine just the other day, i put about 6.5 to 7 quarts in and its right at full....anybody else notice this? and yes, i waited 20-30 minutes each time before i checked it
__________________
2002 F-150 supercab XLT FX4/ 5.4 V8/ auto trans/ 3.55 LS
AEM brute force/ Magnaflow duals with muffler deleted/ BamaChips XCal 1
  #2 (permalink)
Old 02-13-2007, 09:16 AM
jimm66's Avatar
jimm66 jimm66 is offline
jimm66 is starting off with a positive reputation.
I'll have to check mine. I had it changed and they put in 6. I'm pretty sure it's right at the full mark. But if you can add more to make it come up to the full mark I would do that. The more oil the better. Obviously not over full!
__________________
2002 F-150 XLT supercab FX4 5.4, true blue, Westin oval bars, lo-pro, piaa horns, rancho 5k's,
husky liner mud guards, trail-seal, sirius, fire extinguisher, mag-lite, tail-gate-easy-lift, bfg at ko's, custom si-do pipes, mag. 18 " & mag tips,
garmin 660, wet-okole seat covers, putco bed rails, bed-rug, recon 3rd. brake lite, led hitch cover. kenwood-mp242 hu, pioneer speakers,
  #3 (permalink)
Old 02-13-2007, 09:42 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
Yes, Ford says 6qt's. It will show 1/2 on the stick which is in the normal "do not add" range. I use 6 myself. More than that can get into the crank and rods causing drag from being submerged in oil.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 02-13-2007, 09:53 AM
as long as its at or below the "full" mark your ok...and thats where im at with 6.5
__________________
  #5 (permalink)
Old 02-13-2007, 11:42 AM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
Shop manual says 2002 6.0 qt. newer 5.4 3v takes 7.0 qt. Anywhere in the hash marks is full.
__________________
20+ years as a tech. Diesel certified.
  #6 (permalink)
Old 02-13-2007, 12:41 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I always go by the dipstick, the '97s take 7, mainly because of the remote oil filter that has a good 6+' of hose going to and from it
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'01 CVPI
'97 F150 5.4L
'09 F150 5.4L
  #7 (permalink)
Old 02-13-2007, 02:50 PM
oscar_007 oscar_007 is offline
oscar_007 is starting off with a positive reputation.
my 2003 5.4 takes 6.5-7 qts of oil. I always like to put just enough oil so it is just below the full mark because I go through a lot of steep hills and I still want oil pressure while doing it. But I don't go above the full mark.
__________________
Powered by Ford
  #8 (permalink)
Old 02-13-2007, 09:54 PM
B's FX4's Avatar
B's FX4 B's FX4 is offline
B's FX4 is starting off with a positive reputation.
i have a 5.4 2002 4x4 and i put in 6.5 because if i put 6 in i somehow burn a half qt at 3k so this way by the time 3k comes im still at 6.....plus with 6.5 the dipstick looks better to me anyways...
  #9 (permalink)
Old 02-15-2007, 07:20 PM
ls973800 ls973800 is offline
ls973800 is starting off with a positive reputation.
My 2003 F150 4.2 takes almost 7 full quarts. I change my own oil and filter every 5000 miles and use Ford 5W20. The 7th quart actually only uses 800ml according to the gage on the side of the bottle to bring the oil level right to the full mark.
I always start the truck after filling it with six quarts to allow the oil to circulate through the new filter. After sitting for a few minutes, I then fill to the full mark.
Tags
2002, 400, 92, 97, c6, cars, dose, f150, f250, ford, hold, list, oil, takes, tran
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
