Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-13-2007, 09:49 AM
marioc956 is starting off with a positive reputation.
Power window problems
I just started to have problems with my pass. side window it will go up but get stuck on the way up. It will go then slow down and go again would this be my motor or gears and if its the gears I know I can get a rebuild kit for that but I checked my local auto parts store and they only have one kit that says will only fit late modle regulator which one would I have my truck is a 1988 ford f150.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-13-2007, 10:03 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Early/Late: Depends on the number of teeth on the metal drive gear which fits atop the plastic gear. Late style means after 1969.
This number below is what Ford car/truck parts book lists for all 1970/89 cars & trucks. It fits 1990 and later (how much later, I don't remember...have no books after 1989).
D0AZ-62234A24-B Gear Kit
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #3 (permalink)
Old 02-13-2007, 11:46 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Most of the time it is the plastic clutch. Take the gear housing apart. Clean the broken plastic out. Re-lube with synthetic brake grease. Drop 3 each 3/8" or 10MM ball bearings into the mechanism. Put the cover back on and reinstall. You can get ball bearings at most hardware stores. I have done this many times.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #4 (permalink)
Old 02-13-2007, 12:06 PM
Ford Parts Guru
I forgot to mention in my above post that D0AZ-62234A24-B is the gear repair kit...not the entire motor.
__________________
  #5 (permalink)
Old 02-13-2007, 06:58 PM
Torque1st's Avatar
Posting Legend
The power windows in my 94 Explorer used the same old guaranteed failure mechanism as the 70-89 vehicles did. I think that was one of those planned obsolescence things. They had a 100% failure rate. Kind of like the guaranteed to fail nylon cam timing gears or newer chain guides and the absolutely designed to fail 10-cut lock cylinders. Then of course we have the always leak AC fittings, always fail door switches, and the never not fail blend door mechanisms. I think I could do an energizer bunny on part failures here. Bill could probably name of a LOONNNNGGGGGG list. Ford keeps on using the same failed designs tho, but then Ford does not consider them design failures...
__________________
Eric
73-79 FAQ & Info
Garage Forum FAQ
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
