Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Sign in using an external account
Register Forgot Password?
View Poll Results: What cam are you using with Tim's new zero-deck pistons
Comp Cams 255DEH 1 5.88%
Comp Cams 265DEH 1 5.88%
Comp Cams 275DEH 0 0%
Comp Cams XE256H 1 5.88%
Comp Cams XE262H 2 11.76%
Comp Cams XE274H 2 11.76%
Comp Cam with Retro-Fit Hydraulic Roller Lifters 4 23.53%
Comp Cams single pattern cam (In. & Ex. same duration) 0 0%
Custom grind 3 17.65%
Other brand of cam and/or Bacon 3 17.65%
Voters: 17. You may not vote on this poll
cam choices for Tim's new flat-top zero-deck pistons
Old 02-13-2007, 07:56 AM
madrockwyo's Avatar
madrockwyo madrockwyo is offline
madrockwyo is starting off with a positive reputation.
cam choices for Tim's flat-top zero-deck 400 pistons
please indicate your favorite cam that you are using or planning to use with Tim's new pistons for the Ford 400
__________________
Scott
1979, F250 4x4 400/C6 reg cab XLT Ranger Chrome Yellow/ White
2001 F150 Super Crew 4x4 V8/auto
1979 F150 4x4 351m/manual parts truck; 1963 Ranchero rolling chassis
1967 Bronco wagon 4x4 289/3 on tree
1961 and 1963 Ford Falcon Rancheros 170/3 on tree
Old 02-13-2007, 11:44 PM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
I don't know that you can run the 262 - looking into that. It's a pretty high compression ratio. Which heads...aussie or stock
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
Old 02-14-2007, 11:01 PM
madrockwyo's Avatar
i am using stock iron heads
__________________
Scott
Old 02-15-2007, 12:11 AM
i'm trying to get info gathered up to see how these combinations are handling the octane rated fuel. You might want to hold off a bit...at least have the dcr worked out...it looks like the 262 might not be aggressive enough...not sure. DO you want to burn premium or 87 or ?
I'll be burning propane with a similar build but might be able to burn 92...but I have the oz heads and much better quench. It might be a good idea to have some material taken off the piston..tim does that...well see ...i hope
__________________
Old 02-17-2007, 06:45 AM
madrockwyo's Avatar
Bump, any more input to poll?
__________________
Scott
Old 03-03-2015, 01:04 PM
kopfenjager's Avatar
kopfenjager kopfenjager is offline
kopfenjager is starting off with a positive reputation.
Scott Newman
(Bump) old thread, but curious what people have found.
__________________
Building Big Blue.
Similar Threads
what clutch to use? Tim Meyer performance build breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-19-2015 12:26 PM
335,385 series distributor. mustang81 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 04-10-2013 10:02 AM
Cleveland 400 Rebuild(DAILY DRIVER) Blinker Fluid 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 13 12-09-2011 06:46 AM
CR for 400? MBDiagMan 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 09-05-2007 07:23 AM
anything new on CR ratio and cam selection? roger dowty 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 12-04-2006 11:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
