Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 02-11-2007, 12:12 AM
afreemanmd afreemanmd is offline
Garage is empty, add now
afreemanmd is starting off with a positive reputation.
Remind me why I like Ford...
Ok,
So i started to look at the Chevy and Dodge fullsize lines and comparing them to the Fords.
I can't speak for long term build quality or durability, but from the just the specs, ford seems a little behind... especially since they just completely re-did their Superduty's for '08, you thought they would be ahead...
The biggest issue for me is side-curtain airbags... (maybe I'm a little biased because they saved my dad's life) but still IMHO, Ford really dropped the ball on this one. The dodge's and GMC's got 'em, and Ford should have put them in when the redesigned...
The dodges also come with a factory option remote start, AND the cummins diesel.
I love Ford and its the only truck I've driven, but seriously, I'm beginning to question my loyalty, especially with the airbag thing...
Somebody please remind me why I like the Fords so much. Sure, IMHO they look the best, but I'm just trying to think safety too
I'm not bashing Ford (or anyone for that matter) but some objective info would be great) Yeah, its a ford forum, so it will be biased, but hey, thats fine with me, I LOVE my ford Excursion
Thanks!
Isaac
  #2 (permalink)
Old 02-11-2007, 10:51 AM
93RangerXL4x2's Avatar
93RangerXL4x2 93RangerXL4x2 is offline
93RangerXL4x2 is starting off with a positive reputation.
good for you, you shoudl know that ford can still out pull all of them,
__________________
1999 Ford F-150 Reg Cab, 4.2L V6 8 ft Box, HD Suspension, 309,986 kms+
2002 Ford 250 SD 8' EX Cab 230,000K+ Original
1995 Diesel 7.3L PSD 747,000KMS,
1998 Ford F-150 Ex Cab XL 4.2L 3.55 460,948kms
1994,1995 f-150's R/Cab both Original, Ford For Life
s youtube FordmanHaulit3002010
  #3 (permalink)
Old 02-11-2007, 11:18 AM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Which is all well and good...if that's what he cares about. He blantantly said safety...which the Ford is definetly lagging behind in, along with many other things.
There are a lot more Dodge work trucks around here now...and it's not too difficult to see why.
All we can do is hope for a redesign to catch up with the others, they're quite behind now.
  #4 (permalink)
Old 02-11-2007, 03:28 PM
Americanmadeford's Avatar
Americanmadeford Americanmadeford is offline
Americanmadeford is starting off with a positive reputation.
If airbags saved your father's life and you can't have peace of mind with out them, then don't buy a Ford. I can see why you would want to have the side curtain airbags.
However, I, like probably the majority of buyers, (evident by Fords lack of standard side curtain air bags in a lot of their cars) don't car. The only safety feature I like to have is ABS, and even that isn't a deal breaker for me.
  #5 (permalink)
Old 02-11-2007, 04:07 PM
CampSpringsJohn CampSpringsJohn is offline
KY Chapter LDR
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Safety is a legitmate concern. I love the cummins engine that Dodge uses as well as Ford and GM in their bigger truck lines. The problem with Dodge was that everything else is light duty when compared to Ford or General Motors in their heavy duty work trucks. To the best of my knowledge, 12,000lbs GVW was the biggest Dodge you could buy until now. If I was looking for a new truck, I would look long and hard at what Dodge has to offer with their 4500 and 5500 series out. Of course this being the first year for them you might want to hold back a year or two and let them work out the inevitable bugs that they will have. As for the cummins engine, I wish they'd stayed with the 5.9. It truely had stood the test of time, but I know they had to go with more cubic inches to get the power with the ever more stricter emissions controls. Not that I would do this, I have seen people swap both duramax's and powerstrokes for the 5.9. I've never seen anyone put a powerstroke in a Dodge, or a GM. Nor have I ever seen a Duramax in a Ford or a Dodge.
  #6 (permalink)
Old 02-11-2007, 04:36 PM
the ram 4500 and 5500s mhhmmm I have seen them plenty of pictures theres a ton of comercial fords, dodges want in, bottom line Ford is Superduty, set the maximum load. dodge coudl take it they all get abused, but one one gets used more, for the Tough stuff
__________________
  #7 (permalink)
Old 02-11-2007, 07:11 PM
NickFordMan's Avatar
NickFordMan NickFordMan is offline
NickFordMan is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by afreemanmd
Ok,
Thanks!
Isaac
Don't go taking this as anything substantial...but as far as I can tell, the SD is built much stronger than the other trucks, sturdier, with more girth. Just because there is an absense of airbags doesn't mean they aren't as safe. I'll try and find some safety tests to comapre between the bunch. I may be completely wrong, but i'll see if I can prove myself right.
__________________
Built Ford Tough
  #8 (permalink)
Old 02-13-2007, 06:37 PM
Musclecar_Fan's Avatar
Musclecar_Fan Musclecar_Fan is offline
Musclecar_Fan is starting off with a positive reputation.
Quote:
Are you for real?
The 4500 and 5500 just debuted last week. I doubt you've even seen one yet let alone one that has fallen apart due to tough work and abuse.
__________________
There's no replacement for displacement.
  #9 (permalink)
Old 02-13-2007, 06:51 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
2003 Ford F-250
92f150I6 is gaining momentum as a positive member of FTE.
Quote:
I would have to agree. I couldn't care less if my vehicle had any airbags. Just need seatbelts to satisfy me. Nor would I really care if my superduty didn't have ABS. The only time I needed the ABS, it didn't do anything, and that tree stopped me faster anyway. Always seems to pulse when I don't need it though.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
09 Challenger RT
A bunch of motorcycles, other cars, and a Quad.
  #10 (permalink)
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
I wouldnt look at anything but a Ford for a work truck. What people see in Dodges is beyond me. Cummins maybe I dont know. Stick with Ford you wont go wrong. Theres one reason Ford outsells Dodge there just better overall truck.
  #11 (permalink)
Old 02-13-2007, 07:24 PM
yeah,
I still think ford makes an excellent truck, and IMHO, it looks the best, and based on the specifications, it can hands-down out-tow any other truck.
But, around Dallas/Fort Worth, where I live, It may just be me, but it seems like there are a lot more dodges than there used to be, but that may just be becase I'm paying attention now. There have always been TONS of Fords. By the way, at least in my case, what I'm talking about wouldn't be a work truck, just a daily driver, with recreational towing.
But here is some interesting stuff to consider:
On Dodge's website, in '06 the Ram did seem to get some pretty good reviews:
•Truckin' Truck of the Year
•Peterson's 4-Wheel Off Road 4x4 of the year
•IntelliChoice best overal value - full size pickup
But ford's not doing to shabby either:
(I couldn't find exactly what they were)
•Best use of technology in a production pickup
•Truck of Texas
Its gotten several awards, and it hasn't even come out yet!
I'm not bashing Ford at all, I just wish they would have put some more time, money, and thought into passenger safety/airbags when they re-did an otherwise excellent truck.
Just something to gnaw on
Thanks for all the replies!
Isaac
  #12 (permalink)
Old 02-13-2007, 07:46 PM
Quote:
Originally Posted by Musclecar_Fan
Are you for real?
yeah and Ford had for years. Now they got a 450 with bed. I proborly never well see a Dodge 4500/5500 lol but I well see about 20+ 450/550s a day
__________________
  #13 (permalink)
Old 02-13-2007, 08:48 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
Oh yeah? Well I just got done driving our GMC 8500, which totally PWNs every little thing that Ford has so it must be the toughest truck in like the whole world!!!!1111oneoneone It has to, it says 8500 on the side!
All the while my 2000 5.4 with 84K is in the shop getting new head gaskets because a design flaw with the intake gasket caused it to leak coolant into the intake and subsequently blow the headgaskets from rust and overpressure. Remind me why I like Ford again. Reliability what?
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #14 (permalink)
Old 02-13-2007, 09:17 PM
yes Fords got one to compete, as for your 2000 with a problem at only 84,000 is nothing to complain to me about it, I just recently put all new brakes, drive shaft, i hit a pile of wood so its dented, the batterys from 1998, and its has 223,700 kms its had no problems to over strees about, its a 400,000 bond truck.
__________________
  #15 (permalink)
Old 02-13-2007, 09:33 PM
Around 1500-2000 dollars worth of engine work before 100K miles? That's rediculous. If that's considered normal for a Ford, count me out. It also needs some new ball joints and the power door locks are worn out.
Those last two aren't really that big of a deal, but all within around 5-10K miles combined with the engine work isn't acceptable as far as I'm concerned.
Mike
__________________
Tags
64, negitives, positives, powerstroke, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
