99 f250 5.4 engine miss - Ford Truck Enthusiasts Forums
Old 02-10-2007, 01:37 PM
joe911 joe911 is offline
joe911 is starting off with a positive reputation.
I have a 99 f-250 w/ 5.4 It has a bad miss at 1500 rpm's under a load ,any answers? It has 120,000 miles
Old 02-10-2007, 01:38 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Thread moved to 5.4L Engine forum.
Welcome to FTE Joe. You should get some help in this forum. Enjoy your stay.
-Matt
Old 02-10-2007, 06:17 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome
If it's never had plugs put in it, they are past due. I would also supect a bad COP (coil) Have you scanned it for codes?
Old 02-15-2007, 09:53 PM
Thanks for the reply,I think I found the problem,clogged fuel filter.We will see if it takes care of the problem.
Old 05-31-2007, 10:52 PM
Still missing
The fuel filter was not the problem .Think i'll go for the cop boots.
Old 08-01-2007, 04:45 PM
tenn250 tenn250 is offline
tenn250 is starting off with a positive reputation.
It's probably the COP boot....
If you search 'miss under load', your post comes up right below a 4.6 hesitation under load when HOT post.....read my reply there. Long story short, I have a 99 250 5.4.....had the miss under load thing for 2 years....#7 cop boot split, rest were fine....replaced it...runs like new. 15 bucks at Advance. Good luck and let me know if you get it fixed.
99 f250 with 5.4 1970 Nam Vet Modular V8 (4.6L, 5.4L) 7 06-10-2014 01:57 PM
99 f250 5.4 start-up idle jdapmc 1999 to 2016 Super Duty 5 12-15-2012 01:09 AM
Where is the fuel pump relay on a 99 f250 99BlackF250 1999 to 2016 Super Duty 0 12-07-2009 03:54 PM
99 f250 missing and shuttering, no codes exploder1019 1999 to 2016 Super Duty 7 02-25-2005 11:56 AM
99 F-250 5.4l V8 How many quarts?? Stab Oil & Lubrication 5 05-01-2002 02:09 PM
Tags
1500, 2001, 54, 54l, 6, 99, engine, f250, ford, load, misses, missing, pulling, rpm, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
