6.2L V8 Discuss the 6.2L V8
6.2l Block Line
Old 02-09-2007, 06:37 PM
f460's Avatar
f460
f460 is offline
6.2l Block Line
Cleveland casting is now preparing the mold line for casting of 6.2l blocks.
These are iron and for trucks. They are to be assembled at windsor engine plant in Canada. An aluminum DOHC version is to be assembled at Romeo,Michigan engine plant. Should be up and casting blocks by fall 2007. Production is to start by end of year to support launch of 6.2 Boss, yes management still refers to it as Boss V8.
Old 02-11-2007, 06:28 PM
slipnotic's Avatar
slipnotic
slipnotic is offline
Is the F-150 going to get the new 6.2 , because Truck Trend was acting like they were only going to put it in the Mustang. Truck Trend also said Ford was going to push for the Diesel in 2008 or 2009 instead of new V8.
Old 02-11-2007, 06:58 PM
NickFordMan's Avatar
NickFordMan
NickFordMan is offline
This engine is a SOHC isn't it?
Old 02-12-2007, 02:37 PM
captain p4's Avatar
captain p4
captain p4 is offline
Rumors say sohc 2v for truck apps, dohc4v for performance apps - just like the mod lineup used to be.
Old 02-12-2007, 03:30 PM
f460's Avatar
f460
f460 is offline
From what I have been told and from the numbers to be cast, the F-series is going to get the 6.2l.The 4.4l diesel block is CGI and management is deciding right now where the block is to be cast.Now the aluminum block, is to be cast by another supplier and that is dohc.
I personally have not seen a complete engine, so I can not tell you any more about it.
Ward's auto reports had a story about a week ago titled" Ford intends to be V8 BOSS". It really does not give that much info except that management plans on giving up nothing, and feels the new V8 is more than competitive with anything anyone else has, including the toyota and GM 7L. The bore size for the 6.2l block is over 4" and the bore spacing allows for a healthy bore. Not quite a 460 but larger than the old windsor blocks.
Hammer40330
1999 to 2016 Super Duty
16
05-09-2016 08:42 AM
JimRay
6.2L V8
12-29-2013 04:43 AM
LindenBruce
03-03-2010 12:00 AM
f460
6.2L V8
34
08-22-2009 12:11 PM
Quick Reply: 6.2l Block Line
