Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 6.2L Boss
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
6.2L Boss Discuss the upcoming 6.2L V8
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-09-2007, 06:37 PM
f460 is starting off with a positive reputation.
6.2l Block Line
Cleveland casting is now preparing the mold line for casting of 6.2l blocks.
These are iron and for trucks. They are to be assembled at windsor engine plant in Canada. An aluminum DOHC version is to be assembled at Romeo,Michigan engine plant. Should be up and casting blocks by fall 2007. Production is to start by end of year to support launch of 6.2 Boss, yes management still refers to it as Boss V8.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-11-2007, 06:28 PM
slipnotic is starting off with a positive reputation.
Is the F-150 going to get the new 6.2 , because Truck Trend was acting like they were only going to put it in the Mustang. Truck Trend also said Ford was going to push for the Diesel in 2008 or 2009 instead of new V8.
  #3 (permalink)
Old 02-11-2007, 06:58 PM
NickFordMan's Avatar
NickFordMan is gaining momentum as a positive member of FTE.
This engine is a SOHC isn't it?
__________________
Built Ford Tough
  #4 (permalink)
Old 02-12-2007, 02:37 PM
captain p4's Avatar
I'll sleep when I'm dead
captain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to behold
Rumors say sohc 2v for truck apps, dohc4v for performance apps - just like the mod lineup used to be.
__________________
-Paul
STGs Minions - Broken Bronco Guy
78 Bronco 400 c6 np205 d60/sterling10.25
OBA, 36" hummer tires, some other stuff
2003 F350 Supercab shortbed FX4 6.0 PSD
  #5 (permalink)
Old 02-12-2007, 03:30 PM
From what I have been told and from the numbers to be cast, the F-series is going to get the 6.2l.The 4.4l diesel block is CGI and management is deciding right now where the block is to be cast.Now the aluminum block, is to be cast by another supplier and that is dohc.
I personally have not seen a complete engine, so I can not tell you any more about it.
Ward's auto reports had a story about a week ago titled" Ford intends to be V8 BOSS". It really does not give that much info except that management plans on giving up nothing, and feels the new V8 is more than competitive with anything anyone else has, including the toyota and GM 7L. The bore size for the 6.2l block is over 4" and the bore spacing allows for a healthy bore. Not quite a 460 but larger than the old windsor blocks.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
