steering stabilizer
If you just want a stock replacement Monroe makes one, just go to there website. I think it was around $39.99. If you want some type of performance I'm sure there are plenty of companies.
http://www.autopartswarehouse.com/ap...999&partid=196
Originally Posted by hambonz
Thanks, I have been looking at that system for $103.
Originally Posted by bdrummonds
I added the skyjacker dual stabilizer kit to my truck in 03 and it works great, Back then the whole kit with cartridges was only about a hundred bucks.
Originally Posted by sean23johnson
do the shocks hang down low? i just bent my stocker playing in the snow. i am trying to find one that mounts above the steering. dr sells a kit but it is like $400. guess ill have to fab up my own.
No they are not stock. Although they should be since without them bump steer is more of an issue. I ran the dinky stock one on my '01 for 30,000 miles. That was 20,000 miles too many. The standard set up for them is real low. The good part about that is it gets your attention before you hammer on the pricier things that follow.
I agree w/bdrummonds that the beefier is harder to bend, but 7000-9000lbs of truck can bend most anything with ease.
Austin
Austin
I would recommend the dual steering stabilizer if you are going to be running larger tires. I have the Skyjacker dual steering stabilizer and it is great turns alot smoother than stock. Rock Ram makes a hydraulic system but it is $$$$. As far as why some SD come with them and others dont is beyond me. If you have the mounting points, which I think all SD do have them, get the dual steering stabilizer kit you will not regret it. Hope this helps
