Some interesting info on the 3.0L Vulcan engine... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-09-2007, 12:25 PM
CMOS CMOS is offline
CMOS is gaining momentum as a positive member of FTE.
Found this on the good ol' internet. Thought it might be interesting to some of the 3.0 owners here:
The Ford Vulcan V6 is a 3.0 L (2982 cc/182 in), 60 V6 engine, first introduced for the 1986 model year and originally designed to be the optional engine in the Ford Taurus and Mercury Sable. In 1988, it became the standard engine for the Taurus, and was the only engine available in the Taurus' last years. It has also been used in the Ford Probe, the Ford Tempo and Mercury Topaz from 1992 to 1994 (optional), the Ford Aerostar and Ford Windstar minivans, and the Ford Ranger and Mazda B3000 pickup trucks; it replaced the Cologne 2.9 engine (which it is not related to) as the base V6 in the Ranger.
The Vulcan was a clean-sheet design using the metric system. The engine block is built by Sherwood Metal Products, the intake comes from Ford's Essex Casting, and the engine is assembled at Ford's Lima Engine plant in Lima, Ohio.
The Vulcan is a straightforward pushrod design, with 2 valves per cylinder. Bore is 3.5 in (88.9 mm) and stroke is 3.15 in (80.0 mm). The engine was designed to use electronic fuel injection from the start (there was never a carburetor-equipped version), and was also sold in a "flexible fuel" configuration that could burn normal gasoline, E85 (a blend of 15% gasoline and 85% ethanol) or any mixture of these two fuels.
In 1991, it was updated with lower-friction pistons, a strengthened block, roller camshaft and other changes that resulted in a power rating of 145 hp (108 kW) and a torque rating of 160 ftlbf (216 Nm). In 1998 further improvements were made, with a new intake manifold, changes in engine management and cam timing; output was further increased to 155 hp (115 kW) and 185 ftlbf (251 Nm). A plastic upper intake was added in 2001.
It is likely that Ford chose this name in homage to Vulcan, the mythological Roman god of fire and ironworking, as the engine is a fully cast iron design.
This engine has become very well-known for its durability, and it is not uncommon to find engines running strong at 300,000 miles and beyond.
The Vulcan is now used only in the Ranger, which has been scheduled to end production in 2008. It is unknown which engine will be used in the Ranger's replacement, but Ford insiders report that Vulcan production will end in 2007.
Applications:
CMOS
Old 02-09-2007, 12:44 PM
freirefishing's Avatar
freirefishing freirefishing is offline
freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.freirefishing has a great reputation on FTE.
CMOS
glad my 1993 probe gt i had back in the day had the 2.5 24v dohc mazda engine.
the only other version of the engine for the probe was a 4cyl, didnt know they offered the 3.0.
Old 02-09-2007, 02:59 PM
JeremyJ JeremyJ is offline
JeremyJ is starting off with a positive reputation.
yup, the gt's up to 92 were 3.0's, 93-97 gt's and gts's were the 2.5
i had a 1994 4-cylinder auto. i miss that car, was fun to drive, but i can honestly say my 00 civic is more fun to drive.
Old 02-09-2007, 03:49 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Old 02-09-2007, 04:48 PM
Quote:
Originally Posted by Rockledge
Guess we know when that info was published - only goes up to 2003.
Good stuff.
CMOS
Old 02-10-2007, 04:30 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
It's strange, I had a aerostar with the 3.0 and drove a taurus with the 3.0 and they were both alot quicker than a ranger with the 3.0, I wonder why?
Old 02-10-2007, 06:31 AM
Quote:
Gearing perhaps. Most of the 3.0 Rangers come with the 4:10 rear end.
[shrugs]
CMOS
Old 02-10-2007, 06:41 AM
Yeah, but 4:10's should make the ranger quicker, it can't be weight, maybe it's in the tune, I don't know. The aerostar would excellerate hard and fast.
Old 02-10-2007, 06:46 AM
Rockledge's Avatar
I'd guess a 4x4 Ranger is heavier, too, and has bigger tires.
Old 02-10-2007, 06:49 AM
Even the 2wd ranger 3.0's are slugs compared to other vehicles with the 3.0, there's something different.
Old 02-10-2007, 07:34 AM
Scott_XLT Scott_XLT is offline
Scott_XLT is starting off with a positive reputation.
Perhaps the situation is similar to the 2.3 in the Ranger -- I read it is de-tuned a bit for the Ranger compared to its applications in the Escape/Fusion/Mazda3/Focus in an effort to have it be more durable and handle the heavier loads of truck duty.
Old 02-10-2007, 09:30 AM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Quote:
Originally Posted by JeremyJ
yup, the gt's up to 92 were 3.0's...
Funny...you never think of the 3.slow as a "sport" engine.
Good info both you guys, thanks for that.
Old 02-10-2007, 01:58 PM
BuffmanLT1 BuffmanLT1 is offline
BuffmanLT1 is starting off with a positive reputation.
I find my ranger (91 3.0L) pretty peppy even with 420lbs of sand in the back and 27" tall tires (hurts accel compared to the stock like 25" tall tires). It only has 3.45s out back.
Old 02-10-2007, 02:24 PM
Rockledge's Avatar
Quote:
Your confusing the 3.0L OHV "vulcan" with the 3.0L DOHC "duratec".
Old 02-10-2007, 02:39 PM
RangerFred RangerFred is offline
RangerFred is starting off with a positive reputation.
Is the ranger not heavier then? im suprised; I would think its tuned for torque rather than speed for our application.
Questions for Future Topics Ford Trucks Official Ford Forum : Ask an Engineer 73 09-14-2016 11:47 PM
EcoBoost Engines Ford Trucks Official Ford Forum : Ask an Engineer 13 09-07-2016 12:54 AM
Interesting Oil Visc. TSB HD 1987 - 1996 F150 & Larger F-Series Trucks 6 08-11-2012 10:10 PM
January All Topic SteveBricks S. California Chapter 336 01-31-2012 10:37 PM
Ford's "new" oil recommendations Carbine 1987 - 1996 F150 & Larger F-Series Trucks 26 07-07-2003 05:13 PM
Tags
30, 30l, cylinder, ecu, engine, ford, horsepower, improvements, interchange, numbers, ohv, ranger, upgrades, v6, v6182, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
