Rust, and my Ranger
Old 08-22-2017, 04:02 PM
johnday's Avatar
johnday
johnday is offline
Rust, and my Ranger
Ya, imagine that, rust on an '04 Ranger.
Anyway, I'm easing myself into a bed floor complete replacement, and while under it today, I noticed the fueltank rear support strap bracket was no longer there. I've searched until I've run out of ideas, and haven't found a replacement bracket.
Anyone have an idea where I could get a bracket? The OEM one is riveted to the frame, not that big of a deal to remove what's left, but I need one to replace it.
HELP!!!!
Old 08-25-2017, 09:11 AM
ranger pat's Avatar
ranger pat
ranger pat is offline
I have never seen the bracket anywhere as a replacement part. You might have to fabricate one yourself.
Old 08-25-2017, 10:00 AM
johnday's Avatar
johnday
johnday is offline
Ya, I may have to. As long as it doesn't look "too" redneck, some unistrut and allthread oughta work, both I have in the barn.
My dealer called me this morning and says he might have gotten what I need. They ordered it for me, and according to their catalog, it's called a gusset. We'll see.
Old 08-25-2017, 02:20 PM
johnday's Avatar
johnday
johnday is offline
Got my "gusset" as Ford calls it. The tag on the box said "Vintage Parts", LOL
Also some photos of the floor from topside.
Old 08-26-2017, 09:15 AM
ranger pat's Avatar
ranger pat
Looks like the bed floor was the victim of moisture trapped under a bed liner. If you weld in a new floor make sure to mark all four side of the inside walls so the new floor bolt holes line up nicely with the box to frame torx bolts.
Old 08-26-2017, 09:46 AM
johnday's Avatar
johnday
johnday is offline
Thanks for the tip.
The bed rotted from underneath, there was never a liner in there, and always covered by a tonneau.
I did have a bed mat, but as much as I looked, there was never any water between it and the bed.
Old 08-31-2017, 11:16 AM
johnday's Avatar
johnday
johnday is offline
Picked up a box down in the Duhtroit area the other day, best out of 5 I looked at. Front 2 crossmembers need rebuilding, the rest is just surface rust. After pressure washing, I'm going to use Corroseal to convert the rust, topcoat with Rustoleum, then a thick coat of rubberized undercoating.
Never used Corroseal before, so that'll be different.
Also broke loose all my bedbolts but one, luckily it wasn't the one over the gas tank.
Old 09-03-2017, 08:56 AM
johnday's Avatar
johnday
johnday is offline
Some headway. Cutout the bad spots on the crossmembers, power brushed, power washed, and hung up to dry.
Moved it into the barn for rust converter.
Welder took a dump on me, so I'm going to temporarily bolt stuff together until I get a new welder. Getting too late in the year to be screwing around with lots of other things to get done.
Old 09-12-2017, 08:06 AM
johnday's Avatar
johnday
johnday is offline
Got the rebuilt bed almost ready to be swapped. Removing my original bed likely today, clean up the frame, and have POR on the way. Gotta get this finished up, winter ain't far away.
Maybe some photos later today.
FORD LIFE
05-09-2018 07:16 AM
chukar
07-23-2016 12:33 AM
heymrdj
02-16-2015 01:06 PM
tonyt22
05-08-2014 08:43 AM
edwars2
04-02-2007 06:53 AM
Quick Reply: Rust, and my Ranger
