Flathead distributor vacuum
In general I have heard thet the answer is no, there is not enough vacuum to run the stock dizzie (you have 1/2 total CFM at each carb).
Here is a good techno article on this subject:
http://www.btc-bci.com/~billben/navarro.htm
You can find it at the "Techno Source for the 1932 thru 1953 Flathead Ford" site:
http://www.btc-bci.com/~billben/flathead.htm
There is a discussion about some ideas for fixing the problem (especially that you sould not use manifold vacuum for this purpose). I don't have practical experience with this, but others here will likely be able to help you out with some ideas.
Good luck.
Good luck.
irmacsdaddy
10-23-2010 08:09 PM
K2JJB
05-08-2006 08:58 AM
1953, 53, distributer, distributor, distributors, flat, flathead, ford, head, maintenance, parts, rebuilder, specs, taking, vacuum
