Flathead distributor vacuum
Old 02-09-2007, 11:55 AM
paddleback's Avatar
paddleback
paddleback is offline
Hi! I am in the process of rebuilding a '50 flattie and am planning to put on an Offy 2X2 intake with Stromberg 97's (new). Will I be able to use the stock dizzie and pull adequate vacuum off of one of the new 97's? If not, what other good options are there?
Old 02-09-2007, 08:51 PM
soule46's Avatar
soule46
soule46 is offline
In general I have heard thet the answer is no, there is not enough vacuum to run the stock dizzie (you have 1/2 total CFM at each carb).
Here is a good techno article on this subject:
http://www.btc-bci.com/~billben/navarro.htm
You can find it at the "Techno Source for the 1932 thru 1953 Flathead Ford" site:
http://www.btc-bci.com/~billben/flathead.htm
There is a discussion about some ideas for fixing the problem (especially that you sould not use manifold vacuum for this purpose). I don't have practical experience with this, but others here will likely be able to help you out with some ideas.
Good luck.
Old 04-13-2007, 04:48 PM
F6Guy's Avatar
F6Guy
F6Guy is offline
The stromberg carbs do not have the necessaty vacuum ports to run the factory load-o-matic distributer. Your best bet is a mallery unilite.
larrycaruso
1997-2006 Expedition & Navigator
09-20-2015 09:22 PM
Joe-Bob
S. California Chapter
09-03-2013 07:51 PM
lhud
1997 - 2003 F150
11-21-2010 12:00 AM
irmacsdaddy
10-23-2010 08:09 PM
K2JJB
05-08-2006 08:58 AM
Quick Reply: Flathead distributor vacuum
