Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
  #1 (permalink)
Old 02-08-2007, 09:22 PM
old87 old87 is offline
Garage is empty, add now
old87 is starting off with a positive reputation.
Speed
dunno if true or not-
ACCELERATION PUT INTO PERSPECTIVE
* One Top Fuel dragster 500 cubic-inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a dragster engine consumes 11.2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* Dragsters reach over 300 MPH before you have completed reading this sentence..
* In order to exceed 300 MPH in 4.5 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track, the launch acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid off, the crew worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated $1,000 per second.
The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter-mile (10/05/03, Tony Schumacher). The top speed record is 333.00 MPH (533 km/h) as measured over the last 66' of the run (09/28/03, Doug Kalitta).
Putting this all into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged & ready to launch down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race!
That's acceleration !
__________________
Groovin' on the freeway, gauge is on the red
Gun down on my gasoline, I believe I'm gonna crack a head.
LED ZEP
  #2 (permalink)
Old 02-09-2007, 05:54 AM
3broncocrazy's Avatar
3broncocrazy 3broncocrazy is offline
3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.3broncocrazy has a great reputation on FTE.
Now that is speed!!
__________________
Donnie
79,79,89,96 Broncos Baby
Did you ever notice: When you put the 2 words "The" and "I R S" together it spells "THEIRS?"
IT'S BETTER TOPLESS(Broads, Broncos, and Booze)
Quote:
Originally Posted by evilbeast
you people scare me sometimes!!
"...sailors who drank beer escaped the curse of scurvy..."
  #3 (permalink)
Old 02-09-2007, 10:27 AM
GrayRanger4x4's Avatar
GrayRanger4x4 GrayRanger4x4 is offline
1996 Ford Ranger
GrayRanger4x4 is gaining momentum as a positive member of FTE.GrayRanger4x4 is gaining momentum as a positive member of FTE.
And to think, "THATS ALL MOTOR!!" No N.O.S. on them. Now that's how to build Horsepower, not with a bottle.
__________________
Only two defining forces have ever offered to die for you,
Jesus Christ and the American G. I.
One died for your soul;
The other for your freedom.
Many seem to have forgotten both of them.
Member of the Georgia Chapter
  #4 (permalink)
Old 02-09-2007, 06:21 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to allfishmanndotcom is a name known to all
dont remember if its the same stuff but here is some more of that!
http://www.ford-trucks.com/forums/43...s-to-race.html
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #5 (permalink)
Old 02-15-2007, 11:23 PM
thanks for the link....
Gray- that tagline is BEAUTIFUL!!
if they ever start a tagline collection here- that one should always be first.
__________________
LED ZEP
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
