Reverse sensing system - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-08-2007, 07:53 PM
hopeful 6.0 hopeful 6.0 is offline
hopeful 6.0 is starting off with a positive reputation.
My back up sensors went on the fritz today. When I put it in reverse, it acts as though I am right up against something and sounds a continuous tone (not beeping). I checked for dirt on sensors and nothing is there. I can turn sensors off with dash switch.
Anyone else experience this and what is the fix? I really like having them and don't want to lose the use of them
Old 02-08-2007, 07:56 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Giving the sensors a good cleaning usually fixes the problem.
Old 02-08-2007, 08:02 PM
Tried that, didn't help. I also was going to look for the fuse but manual didn't mention a fuse for this system. Must be linked to another fuse.
Old 02-08-2007, 08:14 PM
TNT in Round Rock's Avatar
TNT in Round Rock TNT in Round Rock is offline
TNT in Round Rock has a very good reputation on FTE.TNT in Round Rock has a very good reputation on FTE.TNT in Round Rock has a very good reputation on FTE.TNT in Round Rock has a very good reputation on FTE.
sorry to ask the obvious, but did you have your tailgate down ???
Old 02-08-2007, 08:15 PM
No, tailgate is up and locked
Old 02-08-2007, 11:25 PM
shoobear's Avatar
shoobear shoobear is offline
shoobear is starting off with a positive reputation.
hey at least yours make some sound!! mine makes no noise and as soon as i put it in reverse it kicks off(light comes on)Not even a beep.
U can try to unplug one sensor at a time to see which one it is.Might be a bad sensor.
Old 02-09-2007, 03:19 PM
I did a little troubleshooting today from some info I found on the Ford service manual DVD I bought on EBay for 23.00 (good deal). One of the suggestions was to do just what you said, unplug one sensor at a time to try and find the bad one. I attacked it from the other end first since I wasn't sure how to unplug the connector from the sensor. I started at the connector to module located behind right kick panel. It looks like I don't have voltage on pins that should indicate voltage. Didn't have enough time to run through whole test though and it looks like connector shown in manual has more pins than mine does. ??? More to come.
Old 02-09-2007, 03:37 PM
shoobear's Avatar
hey the module is behind the right kick panel? That sounds like that might my problem. My relay is good,and all my sensors. But i didnt know where the module was.
gotta go and look......
Old 02-09-2007, 03:46 PM
Yep, the connector is right behind the kick panel but the PAM module is a little higher up. You can put your hand on it but to get to it to remove might require removal of heater duct (or whatever that big black box is under glove box) If yours doesn't make any sound, it might be harder to find.
Old 02-09-2007, 05:16 PM
shoobear's Avatar
wow,i just phoned ford, they want $260 cdn for that module,i guess it has the speaker built into it also.
Old 02-09-2007, 05:21 PM
Wow, what a rip. Yes the speaker is built into the parking aid module (PAM). My next step will be to unplug one sensor at a time to see if that eliminates the fault. If I find a bad sensor, I'll just leave it unplugged or see how much a new one costs
Old 02-09-2007, 05:56 PM
shoobear's Avatar
hey how did u check for the right voltage on the module? I popped it off, its really small for 260! Not sure if thats the problem but there are only three things with the back up alarms,switch,module and sensors.
Anyways how did u check yours?
cheers
Old 02-09-2007, 06:07 PM
I used the instructions from Ford workshop manual. Like I said earlier, I didn't take the time to thoroughly run through all the test points because some of the pintests called out in manual didn't match the connectors I have so I'm not going to rely on that information. Based on the symptoms I have (continuous tone), the manual suggests to check for corrosion or pushed out pins in each connector. That's my next step. If everything looks good from there, it says to install a new parking aid module(not gonna happen)
Old 05-31-2007, 09:57 AM
shoobear's Avatar
u find out what the problem was?
Old 05-31-2007, 10:22 AM
Problem disappeared has has never surfaced again. Don't you just hate those unverified failures. Bound to pop up again for no reason. Probably a moisture or corrosion issue.
reverse sensor Pyancey Excursion - King of SUVs 1 01-16-2013 10:08 PM
Back-up sensors turn off when put in reverse. Rushmore X Excursion - King of SUVs 12 05-09-2012 11:15 PM
Reverse sensors Ryan50hrl 2004 - 2008 F150 9 01-29-2012 03:12 PM
Reverse Sensors...NEED HELP motor-man 1999 to 2016 Super Duty 12 11-01-2009 08:17 PM
08-up rear bumper swap to 99-07 SD - Reverse / Backup Sensors? rwhite692 1999 to 2016 Super Duty 5 03-25-2009 09:04 PM
Tags
2004, backup, f150, f250, ford, fords, forward, module, parts, programming, reverse, sensing, sensor, system, troubleshooting, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
