Gauges on a 1998 F150 not working
Old 03-24-2019, 05:31 PM
Mike Justis's Avatar
Mike Justis
Mike Justis is offline
I have a 1998 F150 truck that has a battery volt meter that would work periodically and when it didn't work I checked the alternator with a multi-meter and the charging system was charging properly. I didn't start the truck for 6 weeks and found the battery was dead when I went to start it. I replaced the battery because it was 7 years old and when I started the truck , 3 or 4 seconds later all of my gauges stopped working including the tachometer. I have lights for the instruments and fuse #5 and #29 are good. I have all the other functions that are controlled by the body module. I assume the #2 relay which is 5 amp rating is overheating since my gauges worked for 3 or 4 seconds. I thought maybe it was a ground issue ,but I'm not sure since there are several things that work that share G201 ground. It had rained a lot while the truck sit and it seemed like moisture had gotten into the cab of the truck. Need some expert help on figuring out what may be wrong.I
Old 03-25-2019, 05:49 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Instrument illumination is separate from instrument operations.
While the fuses might be good, did you verify they are actually passing power 1) through the fuse and 2) to their respective connector pins on the cluster?
Did you check the integrity of the ground connection from the cluster to the grounding stud?
Old 03-25-2019, 07:08 AM
Mike Justis
No sir I have not. I've had to stop working on the truck because of rain. I'm working outside and when the weather changes I'll be able to process and check it out. I'll give a post follow up when I'm able to get back to it. Thanks for your input.
Old 03-25-2019, 07:12 AM
projectSHO89
Give those things a checkout when the weather clears. If none of those pan out, report your specific observations AND measurements for further analysis.
Old 03-25-2019, 09:25 AM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
Connect a battery charger and fully charge the battery. Sometimes a low battery will cause issues with the onboard electronics.
Old 05-10-2019, 10:21 PM
azroxx's Avatar
azroxx
azroxx is offline
I have a Fuse 29 issue on my '98 F150. The PO installed a 10A in place of the 5A and it lasted about 3 weeks. When it blew on me, I looked at online diagrams and found out it was supposed to be a 5A.
I found an old thread with this advice
>>>F29 in the CJB blows when the little wiring harness that goes into the shift lever from the steering column wears through and shorts out to the shift lever.
>>>Remove the column shrouds and repair with electrical tape, at a minimum.
I am going to look up how to access the wires and go from there.
Old 06-28-2022, 09:04 PM
Ecc1203's Avatar
Ecc1203
Ecc1203 is offline
4th Gear
Short in harness, instrument cluster inoperative
I'm having this same issue. GEM is good, fuse 29 keeps burning. I've opened up the steering column shroud, idk which area the bared wire is, can anyone point me to the right location?
Old 06-29-2022, 03:45 AM
Airborne 82nd's Avatar
Airborne 82nd
Airborne 82nd is offline
How do know the GEM is good? did you remove the fuse box and pull the GEM and pin it out
l
Old 06-29-2022, 05:53 AM
projectSHO89
Look at the little wiring harness that runs up into the shift lever tube. They usually chafe right at the lower end of the tube.
Leave the GEM module alone unless you actually know what you're doing.
The following users liked this post:
Old 06-29-2022, 06:56 AM
Ecc1203's Avatar
Ecc1203
Ecc1203 is offline
4th Gear
Replying...
Thanks for the replies....
I can reinstall a 5a fuse and it works, it blows when the column is tilted or when the ride is bumpy.
I'll open it back up and post a pic if I cnt find the wire, not mechanically inclined!
Thanks guys, I'll try it this afternoon I hope
Old 06-29-2022, 07:16 AM
projectSHO89
If you can't find it, just replace the shift lever, it comes with a new harness.
Old 06-29-2022, 05:16 PM
Ecc1203's Avatar
Ecc1203
Ecc1203 is offline
4th Gear
Chafed wire F150
Thanks guys, i believe you led me to it
Old 06-29-2022, 05:17 PM
Ecc1203's Avatar
Ecc1203
Ecc1203 is offline
4th Gear
Chafed wire
jenm34
10-01-2018 02:08 PM
Tileguy66062
06-15-2018 09:12 AM
Chambo28
1999 to 2016 Super Duty
15
12-14-2016 02:51 PM
rogueinla
11-08-2009 01:40 AM
jgleason64
04-14-2009 02:54 PM
Quick Reply: Gauges on a 1998 F150 not working
