Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-08-2007, 12:52 AM
chaparro chaparro is offline
Garage is empty, add now
chaparro is starting off with a positive reputation.
2007 head to head Exp El vs Sub.
Head to Head: 2007 Chevrolet Suburban LT3 4x4 vs. 2007 Ford Expedition Limited EL 4WD
2007 Chevrolet Suburban LT3 4x4Ford Expedition Limited EL 4WD
Powertrain/Chassis
Drivetrain layout Front engine, 4WDFront engine, 4WD
Engine type 90* V-8, alum block and heads 90* V-8, iron block, aluminum heads
Valvetrain OHV, 2 valves/cyl SOHC, 3 valves/cyl
Displacement 325.1 cu in/5327cc 330.3 cu in/5414cc
Compression ratio 9.9:19.8:1
Power (SAE net) 310 hp @ 5200 rpm* 300 hp @ 5000 rpm
Torque (SAE net) 335 lb-ft @ 4400 rpm* 365 lb-ft @ 3750 rpm
Weight to power 19.0 lb/hp20.9 lb/hp
Transmission4-speed automatic 6-speed, automatic
Axle/final/low ratio3.73:1/2.61:1/2.72:13.73:1/2.57:1/2.64:1
Suspension, front; rearControl arms, coil springs, anti-roll bar; solid axle, coil springs, anti-roll barControl arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Steering ratio 17.8:120.0:1
Turns lock-to-lock3.0 3.2
Brakes, f;r 13.0-in vented disc; 13.5-in vented disc, ABS 13.5-in vented disc; 13.2-in vented disc, ABS
Wheels, f;r17 x 7.5 in, cast aluminum 20 x 8.5 in, cast aluminum
Tires, f;r 265/70R17 113S M+S Goodyear Wrangler HP275/55R20 111H M+SPirelli Scorpion STR
Dimensions
Wheelbase 130.0 in131.0 in
Track, f/r 68.2/67.0 in67.0/67.2 in
Length x width x height 222.4 x 79.1 x 76.8 in221.3 x 78.8 x 78.3 in
Ground clearance 9.2 in 8.7 in
Apprch/depart angle16.7/20.9 deg24.1/20.9 deg
Turning circle 43.0 ft43.9 ft
Curb weight 5877 lb6270 lb
Weight dist, f/r51/49%51/49%
Towing capacity 8000 lb 8750 lb
Seating capacity8 8
Headroom, f/m/r 41.1/38.5/38.1 in 39.5/39.7/38.0 in
Legroom, f/m/r 41.3/39.5/34.9 in 41.1/39.1/37.7 in
Shoulder room, f/m/r 65.3/65.2/64.7 in63.2/63.7/67.1 in
Cargo vol behind f/m/r137.4/90.0/45.8 cu ft130.8/85.5/42.6 cu ft
Test Data
Acceleration to mph 0-30 3.0 sec2.5 sec
0-404.44.1
0-506.3 5.8
0-608.9 8.4
0-70 11.511.1
0-80 14.414.4
0-90 19.418.9
Passing, 45-65 mph 5.0 sec 4.7 sec
Quarter mile16.6 sec @ 84.4 mph 16.2 sec @ 84.2 mph
Braking, 60-0 mph138 ft 140 ft
600-ft slalom 55.9 mph avg 54.7 mph avg
Lateral acceleration 0.69 g avg 0.69 g avg
MT figure eight 30.2 sec @ 0.50 g avg30.6 sec @ 0.50 g avg
Top-gear revs @ 60 mph 1800 rpm 1600 rpm
Consumer Info
Base price $40,760 $43,395
Price as tested $51,320 $49,685
Stability/traction control Yes/yesYes/yes
Airbags Dual front, f/r curtainDual front, front side, f/r curtain
Basic warranty 3 yrs/36,000 miles 3 yrs/36,000 miles
Powertrain warranty 3 yrs/36,000 miles 5 yrs/60,000 miles
Roadside assistance 3 yrs/36,000 miles 5 yrs/60,000 miles
Fuel capacity 31.5 gal 33.5 gal
EPA city/hwy econ 15/20 mpg 14/18 mpg (est)
MT fuel economy 15.0 mpg 18.7 mpg
Recommended fuel *SAE certifiedRegular unleaded Regular unleaded
  #2 (permalink)
Old 02-08-2007, 04:18 PM
bg2pres bg2pres is offline
bg2pres is starting off with a positive reputation.
The thing for me to make the Ex above the Sub is the third row automatic laydown feature. YOU STILL HAVE TO TAKE THE SEATS OUT OF THE VEHICLE ON THE SUBURBAN. CAN'T BELIEVE IT... Ford got them there..
  #3 (permalink)
Old 02-09-2007, 09:47 AM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids has a good reputation on FTE.i eat hybrids has a good reputation on FTE.i eat hybrids has a good reputation on FTE.
The EL owns the new burb. Hands Down
__________________
2006 Ford F350 Crew Cab Long bed, 4x4, 6.0L PSD
2006 F150 Ext cab black (traded in on F350)
2001 Ford Excursion, 4x2, 6.8L V-10, 4" lift, 33" BFG A/T (Totaled, May 2009 RIP)
  #4 (permalink)
Old 02-09-2007, 08:45 PM
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
Isn't the 6.0L available in the Suburban? At about 335 hp?
__________________
2009 F450 Lariat CC 4x4
2005 Mobile Suites 36TK3
2011 MKX
  #5 (permalink)
Old 02-09-2007, 11:17 PM
Talking Good for Ford
Quote:
Yes it does and it power is 365 hp. In the Truck Trend magazine they compare the 6.0 sub vs 5.4 Exp. and pulling a 2 ton boat, the subs engine overheat. The gpm were 8.6 the sub and 11.4 the exp. And the exp was faster in flatland and up hill. if you want more inf. log into trucktrend.com and look for 2007 suburban vs expedition.
  #6 (permalink)
Old 02-14-2007, 08:39 PM
NoMo's Avatar
NoMo NoMo is offline
NoMo is gaining momentum as a positive member of FTE.
Quote:
This is the only head-to-head comparison I could find. The Suburban in that comparison had the 5.3L engine. Do you have a link to the article you mention with the 6.0L test?
__________________
2012 Ford Fusion SE I4
2011 F150 XLT CC 4x4 w/3.5L V6
  #7 (permalink)
Old 02-15-2007, 02:43 PM
kenttrudiw kenttrudiw is offline
kenttrudiw is starting off with a positive reputation.
It is now on the home page of Truck trend right at the top.
  #8 (permalink)
Old 02-15-2007, 03:35 PM
NoMo's Avatar
Thanks!
It's interesting to see how the opinions and measurements changed from one article to the other.
On Edit:
Wonder why the Suburban pictured in their article isn't the one they claim to have tested.
__________________
  #9 (permalink)
Old 02-15-2007, 05:36 PM
The good thing is that the Expeditions are getting a lot of write ups in these mags and various web sites.
I believe they are all very positive, the only loss is to the GMC Denali (which cost around $7500 more)
  #10 (permalink)
Old 02-15-2007, 10:44 PM
(+$7500 for Denali) I was a little concerned at this cost, but maybe is correct. Trying to use KBB as MSRP listings, EXPY EL would be about $51K, and Denali about $57K. Biggest diff on paper is 380 horsepower.
Also, according to some registrations, Ford is leading GM on newer large SUV sales.
__________________
2011 MKX
  #11 (permalink)
Old 02-15-2007, 11:18 PM
edgl edgl is offline
edgl is starting off with a positive reputation.
GM has a 100,000 mile warranty now on their 07s.
Tags
2007, 4x4, el, exp, expedition, ford, limited, suburban, trend, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
