Spitting/Sputtering problem - Ford Truck Enthusiasts Forums
Old 02-07-2007, 06:24 PM
IneptMechanic IneptMechanic is offline
IneptMechanic is starting off with a positive reputation.
I have a 2000 F150 5.4. A couple of weeks ago I changed out all 8 spark plugs as it had not been done yet (119000 miles on the truck). I bought new boots to put in also but took them back because the existing ones were in very good shape. This solved the spitting/sputtering feeling that I was getting when accelerating (and cleared the SES light). Until about 2 days ago. The scanner that the auto parts store guy used said that I had a cylinder 5 misfire (same as before) and the spitting/sputtering is worse when I accelerate and when idling (SES is back and sometimes flashes).
Here's my question: bad coil cap, bad fuel injecter, or possibly something else?
Any help would be greatly appreciated
Thank You
Old 02-08-2007, 01:09 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi and welcome to the forum
The most common cause of a misfire is a bad spark plugs, but since you've replaced them and have the same symptom as before, the next likely cause is a bad COP (Coil On Plug).
You can swap #5 COP with another one (#1 is easy to access), and then clear the code by removing a battery terminal for 5 minutes. Drive the truck until the check engine light comes on again and then get it scanned to see what set the code. If the misfire code follows the COP then you know you've found the problem.
Or you can save a bunch of time but spend some money and have your dealer do a cylinder power balance after moving the COP to see if the misfire followed the COP.
Sputtering when accelerating, help! 03XL 1997 - 2003 F150 1 03-05-2014 12:17 AM
Idle real rough cat converter glowing red curtism123 1997 - 2003 F150 3 06-12-2011 10:56 AM
Need help fast Please-2002 7.3 keeps shutting off clarkb 1999 - 2003 7.3L Power Stroke Diesel 9 08-27-2010 09:36 AM
some spit & sputter, hiccups, etc..... scameron 6.0L Power Stroke Diesel 10 09-24-2009 07:24 AM
acts like vapor lok and misses when hot neon4x 1987 - 1996 F150 & Larger F-Series Trucks 5 08-02-2007 08:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
