1998 F-150 Heater Core Replacement - Ford Truck Enthusiasts Forums
Old 02-07-2007, 05:21 PM
BIGTRUCKINCORY BIGTRUCKINCORY is offline
BIGTRUCKINCORY is starting off with a positive reputation.
Im New To This Website. Ive Search Through And Cant Find Anything. Does Anyone Have Any Links Or Specs Or Words Of Wisdom. Im Trying To Replace My Heater Core In My 1998 F-150, I Cant Seem To Get The Whole Dash Out, Especailly The Section On The Passenger Side. If Anyone Can Help I Sure Would Appreciate It....
Old 02-07-2007, 05:24 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Old 02-07-2007, 05:25 PM
BTW, welcome to FTE BIGTRUCKINCORY.
Old 02-07-2007, 08:36 PM
donaldm donaldm is offline
donaldm is starting off with a positive reputation.
I just did mine. whats the hang up? pass side has hiden tabs and a screw at the door under the rubber molding. theres two or three screws you cant see from the seat side one is looking down and two are looking from the engine side use a mirror. the dash has a snap in out up near the windshild pull up and back GENTILLy theres screws that connect the air duck to the dash. see my prior post
heater core help FordGurl83 1997 - 2003 F150 1 10-28-2014 07:37 AM
Heater Hose Question 84StraightSix 1997 - 2003 F150 2 06-09-2014 03:46 PM
I want to bypass heater core, but need help. Melissa Ohmy 1997 - 2003 F150 8 03-03-2014 10:05 PM
how to replace a heater core in a 1998 F 150 brandon olson 1997 - 2003 F150 13 12-30-2013 09:02 AM
Changing Instrument Panel Bulbs 1998 F-150 Maury4 1997 - 2003 F150 1 07-28-2007 02:43 PM
Tags
150, 1998, 2001, 98, change, changing, core, f150, ford, heater, installation, removal, replace, replacement, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
