Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 02-06-2007, 10:35 PM
mongo75's Avatar
mongo75 mongo75 is offline
Garage is empty, add now
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
danny jones
Who makes the best heated filter?
OK, I'm starting to narrow down this WVO thing LOL. I plan on using a hotfox to pull wvo, and now I'm wondering what filter would be best. I want to use coolant only, just to KISS. I'm looking at the Racor Parker Vormax, or the Fleetguard FH23000. I like the bigger filter on the Fleetguard, but I've heard the Vormax is a great filter. Advice anyone??
__________________
Danny PAA member #12
SoCal Chapter Member
E99 F-350 Dually Van turbo 4x4 CC LB 7.3L, AFE intake, 3 gauge pillar, 4" Magnaflow SS str8-pipe, DP Tuner, Swamps 175/146 SS inj, ARP head and bottom studs, Comp 910 springs, ITP Ovrbst, CCV mod, SS HPX, home made Reg-return, Foil Del, ZooDad, Air Horns 320hp/704tq
  #2 (permalink)
Old 02-07-2007, 12:06 AM
Cool6.9DieselGuy Cool6.9DieselGuy is offline
Cool6.9DieselGuy is starting off with a positive reputation.
I've heard about a Stanadyne Fuel Manager 100, apparently it has an 80watt heater built in or something.
  #3 (permalink)
Old 02-07-2007, 06:53 AM
flyboyd8 flyboyd8 is offline
flyboyd8 is starting off with a positive reputation.
The Fuel Manager 100 is perfect for Dino fuel! not enough for WVO or bio, in cold climates, IMHO. The unit I have is complete w/ the 10 psi pump.
Long live the IDI's
Ken In Central NY 23K on WVO
__________________
Ken, Central NY
Mighty Pre-94, (93) F250, 2wd, 7.3 N/A, E4OD, 3.55, ext. cab, 333K hit 333,333.33 on 6-12-11 @ 2:14PM EST, Last 153k on WVO.
  #4 (permalink)
Old 02-07-2007, 08:42 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
"the best" is not the right question. They all will work in some form or fashion. Find out about each of them, the strengths and weaknesses and then try to understand your needs.
Then it should be simple to fine the one that is right for your setup or the one that meets most of your needs.
The Vormax for example, and the only one I know about first hand will be pretty ineffective in warming the oil enough to flow when it's 20F and it hanging on the frame rail in the wind.
I've insulated mine very well and even them it takes some time to get to a temp that allows the oil to flow. There is a device called the Overnighter that works to reduce this issue, but that is an option that is more money and develops other concerns.
IMHO the Vormax is very good if your temps never go below 40F or you have very very good oil. All these things factor in. Also the way you filter can make a difference. Do you cold filter or warm filter.
There is no simple "best filter" answer Only the filter that meets your needs in the way you do things in this highly experimental world of WVO
Erick
  #5 (permalink)
Old 02-07-2007, 08:58 AM
mongo75's Avatar
danny jones
Erick- I plan on warm filtering, to make sure the thinner oil gives up the most crud I can get out of it. I understand what you're saying about the experimenting, but unfortunately, the money situation doesn't alot for a whole lot of experimenting with multi hundred dollar pieces of gear LOL. I live in SoCal, where it rarely reaches into the high 30's, in the winter it usually is around low 40's in the morning. Yesterday it got up to about 78!! I think my purchase may be based off the lower price I can get on ebay or craigslist. We'll see, thanks all!
__________________
  #6 (permalink)
Old 02-07-2007, 11:24 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Those of you that run WVO might find this interesting
http://www.frybrid.com/forum/showthread.php?t=6510
click on the attachment shown at the bottom of the first post. It is labeled Vegetable Oil as Fuel.pdf
You need adobe reader to see it
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 02-07-2007, 03:33 PM
This document has been beat to death on the infopop forum
Erick
  #8 (permalink)
Old 02-07-2007, 03:59 PM
Phydeaux88's Avatar
What do you mean by beat to death?
Discredited?
Talked about at great length?
Somthing else?
The study may not be perfect as scientific studies go but it appears to be fairly solid.
Of course the true test of any study is repeatability. That is others should obtain similiar results under similiar circumstances
__________________
  #9 (permalink)
Old 02-07-2007, 06:26 PM
Talked about at great length.
I'm going to just keep my head in the sand and think happy thoughts. Since there are opinions on every side of this.
Erick
  #10 (permalink)
Old 02-07-2007, 07:00 PM
mongo75's Avatar
danny jones
I can't open the link??
__________________
  #11 (permalink)
Old 02-07-2007, 07:14 PM
Link is working for me
Try this
Go to www.frybrid.com
Once there go to Forums > Vegetable Oil Forum > TECH
Look for a thread called Report on Oxidation and Polymerization of Vegetable Oil. It was first posted Dec 29th.
There are 19 pages of reading on that forum alone. Infopop forum got up to 7 pages before the mods closed it since no one could agree and it got ugly.
All I know is what I do and so far it works. Who knows what will happen tomorrow or 1000 tomorrows.
Happy reading
Erick
  #12 (permalink)
Old 02-07-2007, 07:16 PM
Phydeaux88's Avatar
try to cut and paste
__________________
  #13 (permalink)
Old 02-07-2007, 09:28 PM
mongo75's Avatar
danny jones
I think I know what you're talking about- I read something on copper corrosion and oil polymeration somewhere a couple of days ago- could've been from frybrid.
__________________
  #14 (permalink)
Old 02-20-2007, 11:21 PM
mongo75's Avatar
danny jones
OK- I bring this up again- what's better, a Vormax, or a Racor 6000 series?? Help!!
__________________
  #15 (permalink)
Old 02-21-2007, 11:21 AM
willbd willbd is offline
willbd is starting off with a positive reputation.
Racor with heater blanket
Quote:
I have a Racor with a custom make 200 watt 12 vdc heater blanket.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
Tags
craigslist, fh23000, fleetguard, vormax
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
