I have a 1984
ford f-250 460 4x4.
i was not getting enough gas to the carburator causing the
truck to only run for 10-15 seconds, i give it gas when it starts to die but it still dies. i ran an alternate electric
fuel pump outside the
truck from the tank switch over(i have two tanks), and the truck runs perfect.
I have changed the fuel return valve, fuel relay, oil pressure activated fuel pump shutoff switch, oil pressure gauge sending unit, fuel pump, rebuilt the carburetor, adjusted the floats, checked the Interia switch and all the fuses.
Now my gas gauge is not working. I was told to change the fuel tank switch over valve, so i did that today, and now the truck wont start at all. before it would run for 10 seconds and then die, any ideas on what else it could be?
