Kroil/aero-kroil and Kreen - Ford Truck Enthusiasts Forums
Old 02-06-2007, 01:21 PM
rsylvstr rsylvstr is offline
rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.rsylvstr has a great reputation on FTE.
Everyone talks so highly about Kroil/aero-kroil as a penetrant.
i see they have Kreen Magic Motor Tonic also...is that like Marvel Mystery Oil?
any good?
what is it?
anyone use it in their oil? fuel system?
Old 02-07-2007, 01:14 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Never have, nor had, the need to use "Kreen" in an engine.
Be careful with those kinds of products, as many have strong solvents, that'll strip away any oil film & defeat the purpose of your lube.
Also we don't know what is in these brews at any given time, in what concetrations, nor when the recipe might be changed.
So it's not predictable if, when, nor for how long any product might, or even if it WILL, mix with any given lube, nor what the short or long term outcome would likely be!!!!
Our modern engine oils are a synergistic blend of additives, carefully balanced, such that the sum total is greater than the sum of the individuals, to SAFELY give us all the detergency we need for our engines.
If we come along and add who knows what, in who knows what concentration, we could upset our lubes synergy & cause who knows what kind of mischief!!!!
If we use a good brand name oil in our rides, change it as specified by the manufacturer in our owners manual, for the kind of driving we do, under the conditions called out there , we won't likely need any engine "cleaner uppers" & certainly not strong solvents imo !!!!
I've used Sili-Kroil for over 40 years in my Night Vision Optics lab, for various & asundery things.
BUT, be careful using it around plastcs, rubber, or composite materials, as it can get after some of those things.
Kroil is really meant for use on metal things & it's really good for loosening rusty, or corroded metal parts.
Just some thoughts to ponder.
Old 02-07-2007, 01:35 PM
thanks...I don't plan on using it in my modular motor...just my 92 Galant...
Old 02-07-2007, 02:15 PM
What makes you think your Galant needs a enema?????
If your bound 7 determined to do this, why not consider something less active, that'll clean er up sloooowly, kinda like the deposits formed.
So you don't risk breaking a whole load of stuff loose & clog something vital up.
Maybe something like a dual rated diesel oil for one OCI, or maybe something like some Marvel Oil, for 500-1000 miles, then change the oil & filter.
Old 02-07-2007, 02:34 PM
i have a SLIGHT tick (140k miles)....i've had her since 104k and OCI's of 3k...running 5W-30.
my plan is to run the MMO for about 1k...
Old 02-10-2007, 10:23 AM
MScotty MScotty is offline
MScotty is starting off with a positive reputation.
Kreen is Kroil with other additives that allow it to be added to the fuel tank,as well as the crank case.
I received a sample from the company when I ordered Kroil.
I've run it threw my lawnmower.
I can smell the pine smell that Kroil has as the thing is running.
Penetrating Oil Walleye Hunter 1999 - 2003 7.3L Power Stroke Diesel 31 01-30-2017 09:06 AM
Exhaust stud assistance Brentmez45 2009 - 2014 F150 5 11-05-2016 05:02 PM
Did you break a plug? Use Kroil? Ted928 2004 - 2008 F150 9 07-01-2016 12:19 PM
Lisle spark plug extractor question rcknrbn 2004 - 2008 F150 35 11-24-2011 10:43 AM
Kroil!! It Makes A Difference!! boots6868 2004 - 2008 F150 10 10-30-2007 10:16 PM
Tags
aero, aerokroil, cleaner, ddealers, engine, ford, kreen, kroil, lab, magic, motor, oil, parts, retailers, rubber, silikroil, tonic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
