6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
F450 Is In, Drove It First Today!!
Old 02-06-2007, 11:19 PM
42MTI's Avatar
42MTI
42MTI is offline
Originally Posted by Strut61
42 MTI, with the F450 you increase the payload and towing automatically without going to the 4:88 gear set. You also get larger brakes with the F450 over the F350 and a heavier frame too. Add to the list larger tires and a tighter turning radius by about 5'............to name just a few
Really, it depends on what you plan to do with the truck, present and near future. Either way you get one heck of a truck! Enjoy the journey!
Do I understand this correct in that an 08 F450 has a tighter turning radius than a 08 F350.
Also how does the ride compare to the 03 F350.
Sorry for all the questions, I am really a GM guy, and not real familiar with fords line. A friend did have a 03 Dually though, so that will give me something familiar to compare to.
PS: I am dentist who drives about 30min each way to work, all highway. This will be a daily driver, used to pull a 44' powerboat around the country.
Thanks.
Old 02-07-2007, 08:13 AM
Duanne's Avatar
Duanne
Duanne is offline
I was at a dealer Monday in Oregon and he said the 4:33 won't be available until Spring. So I guess the 4:88 is the only one available now.
Is anyone else thinking of getting an over under behind the transmission? The salesman told me that it would not void the warranty. Of course he is the salesman.
Old 02-07-2007, 09:13 AM
biervergnugen's Avatar
biervergnugen
biervergnugen is offline
If I've read Ford's information correctly for the new series, and that is an 'if', the F-450 has a shorter turning radius than its sibilings. A tighter turning rig would be mighty nice!
Old 02-07-2007, 10:16 AM
toddr's Avatar
toddr
toddr is offline
the sales guy is incorrect - i ordered my 4:30 gears and it is not a problem and yes, f450 will turn tighter because of the wide front axle
Old 02-07-2007, 11:07 AM
cdtruckn's Avatar
cdtruckn
cdtruckn is offline
Fords 08 Brochure Says The F450 With 6 Speed Manual, Or On F450 Automatic With 4.88 Rear Axle IS Governed At 325 HP/600 Ft Torque.
Turning Diameter Is better on the 2 wheel drives only
Old 02-07-2007, 11:51 AM
1968gtcs's Avatar
1968gtcs
1968gtcs is offline
I have been looking into the gear vendor unit.
http://www.gearvendors.com/
I got this email quote from the sales man of gearvendor:
"We do have a unit for your new F450. The unit will bolt directly to your transfer case, you will simply shorten the driveshaft and not other modifications are required. This will lower your engine rpm by 22% on the highway (around 600rpm). 4.30 gears would become 3.35's, 4.88's become 3.80's. The Gear Vendors unit will cost $2995."
Old 02-07-2007, 12:17 PM
Big Dually's Avatar
Big Dually
Big Dually is offline
The new F-450 and F-550 share the same "Dana Super 60" front end. They have beefer axle and is wider than our regular Dana 60 on the front. Since the Dana Super 60 is wider, the tires have more clearance and can turn sharper.
Old 02-07-2007, 12:53 PM
Duanne's Avatar
Duanne
Duanne is offline
Which rear end are you or did you choose?
Does it also drop the gear ratio? (More power?) Would the 4.30 become 4.88? Or does it only go the other way.
Old 02-07-2007, 01:14 PM
1968gtcs's Avatar
1968gtcs
1968gtcs is offline
The device basically adds another overdrive or the ability to split your gears. It is not an under drive unit. I was looking at getting the 4:30's thus my final drive gear would be 3:30's ruffly.
