1996 ranger throttle cable - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-06-2007, 10:20 AM
hoxiii's Avatar
hoxiii hoxiii is offline
hoxiii is gaining momentum as a positive member of FTE.
I'm trying to find a throttle cable for a 1996 ranger 2.3 4x2, but can't anywhere except for the dealership.
Has anyone found one anywhere else? The dealership wants $90 for one, but for that i'm almost willing to repair where the cable stop popped off and call it good enough.
Justin
Old 02-06-2007, 11:28 AM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Boneyard, prolly 5 bucks. There are plenty of Rangers out there.
Old 02-06-2007, 12:03 PM
hoxiii's Avatar
Yeah, but a 10 yo throttle cable is going to be just as stretched out and ready to pop as the 10 yo one that came out of there.
Justin
Old 02-06-2007, 12:08 PM
What happened to yours?
My 13 year old one functions perfectly fine, isn't stretched. Idle is fully closed and WOT is perfect 90 degree open.
I've seen them on eBay. You might try local shops as well...anywhere but the dealer will have them a good bit cheaper.
Old 02-06-2007, 02:59 PM
hoxiii's Avatar
it broke and prior was stretched about 2". truck only has about 140K on it.
Justin
Old 02-06-2007, 03:07 PM
RhinoScores RhinoScores is offline
RhinoScores is starting off with a positive reputation.
How can you tell if it is stretched? I have a 93 3.0 that has a cable that is very rusty.
Old 02-06-2007, 03:46 PM
hoxiii's Avatar
if you get under the dashboard and look at the top of the throttle arm, where the cable goes in you can tell. You pull the pedal up away from the floor and the if the cable comes away from the pedal arm more than about 1/2" it has stretched.
Justin
1989 F350 7.5 Manual transmission accelerator cable oem number needed lisagoud 1987 - 1996 F150 & Larger F-Series Trucks 2 07-09-2015 05:29 PM
How to change accelerator/throttle cable? wdsloot2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 04-07-2014 06:13 PM
Choke cable? cadunkle 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 12-14-2011 07:17 PM
97 Ranger Throttle cable... Hipnotized Ranger & B-Series 3 01-07-2009 09:40 PM
Throttle cable adjustment 90F250351 1987 - 1996 F150 & Larger F-Series Trucks 5 09-01-2007 11:11 AM
Tags
1996, accelerator, cable, change, ford, pedal, ranger, replacement, replacing, spring, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
