which rear-end
Originally Posted by straightexhaust
I was wondering if I have the 8.8 or not I have a 89 f250 351w with a zf 5-speed Thanks, Jason
If it's 5, it's an 8.8.
Received 3,090 Likes
on
Originally Posted by tjc transport
the 89 F250 will have a sterling 10.25 rear axle.
the gvw will determine whether it is a semi floater or full floater.
The 1980/89 F250's with WDR (non locking ) & WFL (locking) use the 8.8 axle. This F250 has 5 lug wheels. While Ford doesn't call it that, this is basically a LD Light Duty F250.
Only the 1985 and later F250 HD's (Heavy Duty) offered the Semi Float 10.25 Sterling.
And some others use Dana 60's, Ford 61-1 full floaters; and Dana 70's.
on
Originally Posted by Kemicalburns
f250's always had 8 lug pattern and run either a D60,D70 or 10.25 sterling. not sure where you get your info at.
Look in the 1980/89 Ford Light Parts Catalog...would you like me to give you the exact page number? Here it is: Section 40, Page 9 (fiche 09-45)
Like I said, there ARE SEVERAL DISTINCT F250's made in the 1980's.
The Heavy Duty (Ford's term) F250's were introduced in 1985 along with the Sterling Axle.
Other F250's also used Dana 60/70 and Ford 61-1.
The Light Duty F250's in the 1980's used the 8.8's. You may have never seen one, but considering what I did for 35 years, I've seen plenty. I'm using the exact same truck parts catalogs every Ford dealer in the world is using.
Go down to your local Ford dealer, and ask to see the Rear Axle Application Chart for 1980/89. Then you can see with your own eyes all the correct information.
See my signiture below. There are 1000's of people on FTE asking parts/VIN questions. With 1800 posts in three months, I've answered more than one.
says axle is 39
Source: 1980/89 Ford Light Truck Parts Catalog .. Rear Axle Warranty Plate Axle Codes. Section 40, Page 7 (fiche 09-43)
on
on
your front axle will be either a Dana 44 ifs, or a Dana 50 ifs. the easiest way to tell the difference between the 44 and 50 is the size of the locking hubs. the 44's hubs are a little smaller than the mounting flange. the 50's hubs are the same size as the flange. and they are not interchangeable. here are a few pics so you can see what i am talking about. this first one is a 89 F250 with a Dana 44
http://i41.photobucket.com/albums/e261/tjctransport/D44hub.jpg
and this is a 89 F250 with a Dana 50
http://i41.photobucket.com/albums/e261/tjctransport/d50-60hub.jpg
