Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-05-2007, 11:17 PM
Bossman89 is starting off with a positive reputation.
429 swap
Hi I'm doing a 429 swap in my '89 f150 and I was just wondering what the big issues would be with doing the swap? One question I have is whether or not I could keep my stock fuel pump and regulate it somehow because of rather high pressure for the carb and if not what would be the best setup because i didnt really want to go with a mechanical fuel pump. Thanks in advance
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-05-2007, 11:58 PM
airharley's Avatar
airharley is gaining momentum as a positive member of FTE.
You can put in a fuel pressure regulator from Holley, Summit, Edelbrock, or any other as long as it has a return for the excess pressure. You may also need to swap the front springs since you are adding a couple hundred more pounds.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
'03 F150 Shortbed 5.4L/4R70W/3.55 LS
Author of the disc brake article for 57-64 F-100's
  #3 (permalink)
Old 02-06-2007, 05:35 AM
79superduty is starting off with a positive reputation.
a carb only requires 10 to 13 lbs of fuel press.
  #4 (permalink)
Old 02-06-2007, 04:27 PM
Thanks i will plan on getting a regulator with a return line then and I was going to go with a set of f250-up front springs from a big block or diesel. I also have a set of older dual shock spring buckets which I thought about using too along with a steering stabilizer shock. Could the front sway bar be changed of a bigger truck because I am really not a fan of body roll?
  #5 (permalink)
Old 02-06-2007, 06:23 PM
airharley's Avatar
A carb should only see 4-6 psi otherwise you will over flow the bowls because the needle and seat wont hold the fuel pressure back. As long as the mounting holes line up and you replace the bushings. But check the f-150 forum to be sure.
__________________
Mark J. Covill
  #6 (permalink)
Old 02-09-2007, 05:04 PM
fordsrgrt is gaining momentum as a positive member of FTE.fordsrgrt is gaining momentum as a positive member of FTE.
what i did when i swapped out my 5.0 for the 460 in my 86 bronco was to by pass the main high pressure pump and just use the intank one and then get a regulator from an auto parts house and your good to go
__________________
so many chevies, so little time
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
