Got a code PO125 today? - Ford Truck Enthusiasts Forums
Old 02-05-2007, 10:49 PM
Fredster Fredster is offline
Fredster is starting off with a positive reputation.
I have a 2000 F-150 5.4L. Got a code Po125 today. Eng. service light is on.
Autozone says it means the pcm has determined that the amount of time it took for the coolant temperture sensor to reach an input value consistent with closed loop operation was to excessive. Can anyone tell me what to check for?
Old 02-06-2007, 01:17 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It means the engine isn't warming up fast enough. Either the thermostat isn't closing completely or the temp sensor is bad.
Old 02-06-2007, 08:37 AM
Where is the temp. sensor on a 5.4? I could not find it.
Old 02-06-2007, 09:18 AM
LxMan1's Avatar
There is one sensor on the drivers side head in front of the #5 intake port. I'm not sure if this one measures coolant temp or the head temp for the gauge.
Old 02-07-2007, 08:44 AM
I cleared the code without doing anything. So far it hasn't came back.
Old 02-07-2007, 09:12 AM
LxMan1's Avatar
Perhaps the thermostat stuck open one time. Might not be a bad idea to change it just to be sure it doesn't stick again if it did. Sticking closed would be worse that sticking open.
Old 02-07-2007, 09:18 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Time for a new thermostat. Replace it now before it causes further problems of a more serious nature.
Steve
Old 02-07-2007, 09:05 PM
I plan on flushing the cooling sys. soon anyway. I will change the thermostat at the same time. Thanks
code po125 other issues that are involved 7240powerstroke 1997 - 2003 F150 1 02-22-2015 04:42 PM
2002 f150 has po125code 4.6 engine James Nelson 1997 - 2003 F150 1 12-20-2014 02:03 PM
Po304 po308 FFEMT32 Modular V10 (6.8l) 2 05-10-2013 08:31 AM
check engine codes silver05fx4 2004 - 2008 F150 4 09-01-2008 03:25 PM
PCM error code PO603 "Help!" case2273 1994.5 - 1997 7.3L Power Stroke Diesel 1 07-17-2006 07:40 AM
Tags
02, 125, 2000, 54, check, code, codes, engine, f150, ford, fseries, mustang, po, po125, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
