Battery light flicker - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-05-2007, 10:47 PM
2danglong's Avatar
2danglong 2danglong is offline
2danglong is starting off with a positive reputation.
came on a month ago, had batts tested replaced a bad one, now it flickers again, not very often, just enough to make you think.
checked the alternator and it looked full...
any ideas ?
Old 02-06-2007, 11:25 AM
johnnysF350's Avatar
johnnysF350 johnnysF350 is offline
johnnysF350 is starting off with a positive reputation.
Alternator is going bad. Alot of times if the regulator is borderline the light will flicker.
Old 02-06-2007, 12:22 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
Yeah a flakey alternator probably or lord help you a loose connection somewhere. Alternators will start to get intermittant when the brushes or regulator are on their way out. A low voltage output will cause the light to flicker. An output that is jumping around will also cause the light to flicker.
What do you mean the alternator looks full?? Did you measure voltage at the battery? Was it something like 14volts to maybe 18? What is full?
Good Luck,
Jim Henderson
Old 02-06-2007, 01:46 PM
2danglong's Avatar
Quote:
Jim Henderson
just a joke. do these alternators have brushes that can be changed like in the olden days ?
Or does this mean a new alternator. Either one should be a simple job, but brushes would be cheaper.
Old 02-06-2007, 04:59 PM
I have never had an American made alternator go out on me so I never had to rebuild one except in class. Could be luck, or we know how to build them bullet proof. Had plenty of practice rebuilding Japanese alternators, jeez blow out on schedule it seems.
I DO NOT KNOW if modern alternators have brushes. So it will be up to you to findout or for someone who does know to step in.
If it is brushes, it should be a simple job to replace them, and I would replace the bearings and touch up the commutator while I was at it. For a quick and dirty commutator cleanup, just wrap a piece of say 400 or finer sand paper around it and twist till it is clean.
Good Luck,
Jim Henderson
Old 02-06-2007, 05:11 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I more suspect that a diode in the alternator has been toasted. Alternators have full wave bridge rectifiers, which are basically 4 diodes that convert AC to DC. It is common to have one burn out, especially if you have recently had battery problems. The alternator will still work with three diodes, just not at full capacity, plus you might get some "hum" type interference in your radio. It will change pitch with engine speed.
I can't say if the alternators are servicable. these days people just yank them and get a rebuilt. It isn't like my old '56 F-100, where you actually serviced the generator.
Old 05-19-2007, 02:00 AM
2danglong's Avatar
That's a lot of help Red. 'ppreciate it.
I do have a hum, and I've been wondering about it.
We have a shop here that will reman and warrenty for $ 125.00 they're pretty good, I've heard.
Old 05-19-2007, 02:44 AM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
any ideas ?
With the parallel dual battery setup in these trucks, when one battery starts to go, you must replace both batteries at the same time. If you do not the old battery will quickly shorten the life of the new battery.
Your alternator may be giving you a problem also.
Old 05-19-2007, 10:21 AM
redford's Avatar
Oh....an alternator has 6 diodes, not 4.
Old 05-19-2007, 01:06 PM
2012 SD Snowbuster's Avatar
2012 SD Snowbuster 2012 SD Snowbuster is offline
2012 SD Snowbuster is starting off with a positive reputation.
I have noticed my batt. light is on the whole time my truck is cranking, Is this normal? I dont want to sound like a dope but .... I never noticed this before??
Old 05-19-2007, 01:56 PM
Clint40's Avatar
Clint40 Clint40 is offline
Clint40 is starting off with a positive reputation.
NEVER REPLACE ONE BATTERY, ALWAYS DO BOTH AT ONE TIME. Thats your problem, shouldnt be the alternator.
Old 05-19-2007, 02:44 PM
redford's Avatar
Quote:
Yes, that is normal. Your alternator isn't spinning fast enough to turn the light out when you are crankingthe engine over.
Old 05-19-2007, 02:56 PM
Thanks for the info Redford! I sometimes dont ask questions for fear of getting bashed to death by the hardcore diesel guys. I'm still getting used to all the extra stuff the 04 has. My 99 was a v-10 and didnt have all the lights and such. The 6.0 is beast thats sure, thanks again.
Old 03-01-2011, 06:23 PM
Roadglide Charley Roadglide Charley is offline
Roadglide Charley is starting off with a positive reputation.
04 6.0 powerstroke
new batteries and new altenator
Next place to check for intermittent battery light?
Just got this truck and am learning the ropes on this PSD
Thanks for the help
Old 03-02-2011, 11:33 AM
tigman_tim tigman_tim is offline
tigman_tim is starting off with a positive reputation.
I had a similar issue. Turn out to be the battery voltage sense wire.
Halp! Intermittent high beam flickering mountain dewd 1973 - 1979 F-100 & Larger F-Series Trucks 26 07-16-2016 09:55 PM
lights flicker marine09 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-10-2015 02:24 PM
battery light flicker?? 036.0stroke 6.0L Power Stroke Diesel 4 09-25-2013 11:07 PM
light flicker GaryWestII Escape & Escape Hybrid 0 09-11-2011 12:14 PM
Radio lights flickering Ubbzy 1999 to 2016 Super Duty 3 07-12-2009 12:11 AM
Tags
54, 97, 99, alternator, battery, duty, f150, f250, f350, flicker, flickering, flickers, light, low, mustang, rpm, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
