Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #46 (permalink)
Old 06-27-2007, 09:09 PM
tulenut is starting off with a positive reputation.
They were used in boom lifts,sweepers,skid steers,etc.
Sponsored Links
To remove this ad, register today!
  #47 (permalink)
Old 06-28-2007, 11:43 AM
ghunt is starting off with a positive reputation.
Thought I might throw a few FYI's in here
First off, the four cylinder engine that used a 460 head was, to my knowledge, exclusively used as a boat engine. And it was not related to any four cylinder engine...it was essentially half of a 460, it was about 3.5L, and it was labeled as a Mercruiser if I recall correctly.
The 2.3L industrial engine was identical to the 2.3 n/a from what I've heard. The industrial engines even used the same exhaust manifold as the 2.3L turbo (the E6 manifold)
Also not sure if it was mentioned, but the 2.5L crank had smaller journals than the 2.3 crank.
Oh, and about Ford designing a new 2.3 when they already had the Lima engine...my guess is packaging reasons, on the FWD cars. I know that the 2.3 OHC fits in a tempo because I know of a couple people putting 2.3 turbos into them...and into escorts.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
http://www.cardomain.com/ride/306349
  #48 (permalink)
Old 06-28-2007, 01:47 PM
Nighteyez is starting off with a positive reputation.
Nice looking Turbo Coupe.
__________________
Jim
1985 Ranger 2.3, 5spd, 4x4 w/3.73 limited slip (carport queen#2)
1989 Buick Skylark 2.3 Quad 4-seized engine (carport queen#1)
  #49 (permalink)
Old 06-28-2007, 03:35 PM
Old Rob is starting off with a positive reputation.
Quote:
Originally Posted by darrin1999
"The same is true for the cranks, rods, blocks. NA used cast pistons, and Turbo used forged with dish."
actually thats not true-not all the castings are the same- the turbo crank is 44 lbs, along with the n/a equivalent from the same years, but the old school 1973 pinto 2.3 crank was 34 lbs. the turbo blocks had higher nickel content as well as forged connecting rods.. the turbocoupe block was built to take the extra power vs the original pinto's 78hp, but the pinto will revv quicker because of the lighter rotating assembly. my ideal gas conservative vehicle would be a 1971 mercury capri with a 2.3 turbo block, n/a, with a pinto crank and domed forged custom pistons, running about 11.5-1 compression running dual fuel e-85/propane
I have torn down hundreds of these engines, turbo and N/A, never found any difference in the rods, other than a few did not have cylinder oiling holes. Even got the ford books and they do not show a different rod or crank, untill the 95 long rod 2.3's. Again go to fords books and you will find there was no such thing a a high nickel content. There is the SVO block, which had a higher deck height. You do not need or want dome pistons, you can achieve real static 11.5 easily with flat top pistons. Where do you find a 73 pinto 2.3 crank. The 2.3 was offered in 1974. The big engine in 73 was the german 2.0 and yes that crank weighs approx 34lbs. It is shorter and a different bearing sizes. Look in the bearing books and ford books.
  #50 (permalink)
Old 06-30-2007, 04:04 PM
93ranger86 is starting off with a positive reputation.
So would I be able to put a turbo from a turbo coupe in my 93 Ranger?
  #51 (permalink)
Old 06-30-2007, 09:33 PM
TigerDan's Avatar
TigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud ofTigerDan has much to be proud of
Hi and welcome to the site!
Unfortunately, it's not quite that simple. You'd need the forged pistons that came in the turbo motors to keep them from melting under the added cylinder pressures, and there would be a few other things to do along with the swap, like change the computer, etc. But it's certainly do-able, and has been done...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #52 (permalink)
Old 06-30-2007, 11:38 PM
Would I be able to use a cam for a Pinto in my Ranger even though it has the dual spark plugs per cylinder? Thanks for the help. Oh yeah and what is the stock size of the exhaust tubing on 93 Rangers with the 2.3?
  #53 (permalink)
Old 07-01-2007, 12:07 AM
Quote:
What do you mean "a cam" for a Pinto? Are you talking about a stock cam?
If you want to use a stock cam, don't bother as it will be a waste of time. If it's a 2.0L cam, it won't fit.
Also, your Ranger has a roller cam from the factory, so you can't just replace it with a flat tappet cam without replacing the followers and breaking in the cam (course, you'd have to do that with a flat tappet cam anyway...). An aftermarket cam won't do much for you either, there's plenty of them out there but just throwing one in a stock engine is mostly worthless.
__________________
  #54 (permalink)
Old 07-01-2007, 12:10 AM
Ok I got you. I want to increase the power in my Ranger but I don't know what to do with it. I went on lmctruck.com and looked at an exhaust system, but I don't want my truck to sound like a civic. So what exhaust would be good for it? What is the I.D. of the exhaust pipes? I measured the very tip of the exhaust and it was 2 1/4 but it was expanded near the end.
  #55 (permalink)
Old 07-01-2007, 03:29 AM
darrin1999 is starting off with a positive reputation.
if you want a big power increase for your ranger and dont want it to sound like a ricer, throw a 302 into it
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
  #56 (permalink)
Old 07-01-2007, 10:40 AM
TigerDan's Avatar
Easier said than done, but that's the option I took
I think the ricer sound comes from small diameter pipe with a huge I.D. muffler right at the end of it. Replacing the stock muffler on a Ranger with something like a Flowmaster up in the stock location gives a nice rumble without sounding really ricey, but you're still dealing with a 4-banger here so a little bit of rice sound is inherent. A free-flowing exhaust helps too, but I don't think I'd go bigger than about 2-1/4" pipe, if it's too free-flowing you'll lose bottom end. I believe the stock size is about 1-7/8 or 2". You could buy a cat-back kit, or go to a muffler shop and have them custom build it for you. One of the advantages of a kit is that most of them feature mandrel-bent pipe, which is a little more free flowing than standard muffler shop bends. (Some, a very few, muffler shops have mandrel benders. Most use the typical crush bender which produces a more restrictive bend.)
__________________
FTE Moderator
  #57 (permalink)
Old 07-01-2007, 11:17 AM
Throwing a 302 into it doesn't sound that bad to me, but I don't have the resources or the knowledge to do the swap. How many of you guys know about lmc truck?
  #58 (permalink)
Old 07-01-2007, 11:27 AM
TigerDan's Avatar
LMC is a popular company, most folks I've heard talk about them say they've had good luck with them...though they tend to be a pricey on some things. I looked at their cat-back exhaust, the one that splits a single pipe into duals. It has resonators right on the ends of the pipes, I think that would give you a ricey sound.
__________________
FTE Moderator
  #59 (permalink)
Old 07-01-2007, 11:30 AM
Thats what I was looking at too. I think I'm just going to buy a cherrybomb turbo muffler and go to an exhaust shop and tell them that I want my exhaust that size after the cat. How hard would it be to swap in a 4.0 into it?
  #60 (permalink)
Old 07-01-2007, 12:21 PM
TigerDan's Avatar
Easier than than 5.0 as all the engineering was done by the factory. You'll need the engine and transmission and mounts (the 2.3 tranny won't work with a 4.0, neither 5-speed or auto) the computer and the engine wiring harness. Might be a few other things needed too, depending on your truck's configuration. It's easier to get a donor truck and use everything you need off of it...and then get rid of the carcass afterwards. There are always the little details that ypu overlook in a swap that send you running to the parts store or the wrecking yard...
__________________
FTE Moderator
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
