Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-05-2007, 04:23 PM
rogela is starting off with a positive reputation.
Engine "skips"
I have a 94 E-150 with 5.8L engine. The van is a wheelchair van. While driving the engine "skips" as if a spark plug didn't fire. Sometimes, while idling in DRIVE it stalls but restarts immediately.
A major tune up was done in September 2005 at a Ford dealer. It had a fault code of P0121 and the throttle body and sensor were replaced.
I researched the current problem and the "faulty" TFI module problem seemed to describe what was happening.
I took it to a Ford dealer and so far they have replaced the TFI module, the distributor and the spark plugs and claim they have checked the wiring for shorts and other visible signs of wear.
The ABS light on the dashboard is also on all the time but I don't know if that applies to the current problem except that it might point to a short somewhere and something related to the EEC is also loose and only causes the "skip" where it is jostled while driving. The Ford delaer says that it also "skips" while idling in the shop.
Currently they are "shotgunning" for potential areas before replacing the PCM.
Any help would be appreciated.
TIA - Jim
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-05-2007, 05:58 PM
subford's Avatar
subford has a very good reputation on FTE.subford has a very good reputation on FTE.subford has a very good reputation on FTE.
I take it they did not own an Analog voltmeter to check the voltage before they changed all of that out.
If they did they could have checked to see if the voltage for TPS was between .95 and 4.95 Volts and moving smoothly across the scale to see if it was bad or not. Did they use a breakout box?
I would say spark plug wire or an injector is bad, I do not see a PCM as being the problem.
Did they do a compression check?
A vacuum leak could also do this.
  #3 (permalink)
Old 02-05-2007, 06:11 PM
New spark plug wires last September. The injectors and the fuel filter were cleaned recently.
Vacuum leak? I thought that's what the PIP/TFI/PCM did away with? Never-the-less I'll ask the mechanic in the morning.
Thanks - Jim
  #4 (permalink)
Old 02-05-2007, 06:22 PM
subford's Avatar
Thanks - Jim
The PIP/TFI/PCM have nothing to do with vacuum.
PIP - Profile Ignition Pickup
TFI - Thick Film Ignition system
PCM - Powertrain Control Module
  #5 (permalink)
Old 02-06-2007, 02:09 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I am sure they have put a code reader/scanner on it? I would start looking for something unusual like water in the fuel or something like that.
__________________
Dave F
1989 F250 XLT Diesel
  #6 (permalink)
Old 02-09-2007, 05:26 PM
After replacing the TFI module (caused stall while idling in Drive) and the distributor and a whole lot of checking wiring, injectors with an ocilliscope, etc. they called in a Ford engineer. The consensous was the PCM. The PCM was replaced and it runs great!
Thanks for all your help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
