You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
How do you guys with manuals get a good burnout going? Auto is easy...slam the brakes and then the gas... manuals giving me some issues, so I turn to the diesel comp guys, since we have no gas comp forum.
Stop the truck while in first and just hold the gas down?
Heel toe braking, this is a technique used for downshifting when racing. But im sure it would work for a burn out. Just use the ball of your foot to press the brake, while doing that turn your foot and use your heel to press the gas at the same time. Hope that makes sence.
__________________
2000 F350 7.3 lots of mods SOLD
2013 F350 6.7 stock... NEW
Zach, usually the way I do it is put it in second gear try to pull the truck to a stop with the brakes and lay down on the throttle. Sooner or later the rear tires are going to overcome wanting to stop, and let the burnout ensue!!! Alot of times my front tires start skidding, but it will hook sooner or later. In my gassers, I did the heel toe thing and just dropped it. That makes me nervious in this machine. It's got enough torque to really tear some shizzle up. Though I'm sure it would burn the tires just the same. Sooner or later, alcohol will end the debate of weather or not I should drop it. I'll let you know when it does.
hold the gas down drop the clutch and stab the brake never lettin off the throtle.i have ben noted to use a vice grip with the jaws wraped in blacktape to pinch off the rear rubber brake line to get a nice rosty toasty goin for pic's dont ride around with it pinched off tho
__________________
71 F250 300 4sp w/pto 4x4
92 F150 300 w 5sp 4x4
2000 F250 4x4 super duty 7.3 power stroke
01 ranger 4.0 4x4 (wifes)
Thanks for all the help guys. I used RubberDuck's way, as that was kinda what I was thinking beforehand, coast to a slow roll, hit the brakes, then the gas, and increase both. Tires unlock, truck comes to a quick stop, and voila...lots of smoke for my entertainment!
Thanks guys, I'm sure all methods will come in handy!
if you want lots of smoke, and not just from the tires. simply press in the clutch, put gas to the floor and release clutch. somethings bound to burn and/or smoke.
i road around with a buddy that use to do that to a tempo, it didnt fair to long.
__________________
96 F150 Eddie Bauer rust free 2WD. 306/4R70W, Keith Black rotating assembly, E303 cam, GT40 heads, 1.72 rockers, Trick Flow intake, 30lb injectors, 75mm BBK throttle body and MAF, MSD ignition, long tubes/duals, B&M shift kit, 4.30 w/ Detroit locker
94 F150 4x4. 302, ZF5 swap, 33X12.50 BFG KM2s, 4.10s, Aussie lockers, D44 SAS, NP205 twin sticked, 4BT swap coming soon...
Yes a good line lock kit is the best way and a lot better for the truck.
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
