injector problems?
Old 02-04-2007, 09:30 PM
Weedeater's Avatar
Weedeater
Weedeater is offline
injector problems?
I have a '96 7.3. Bought it with 170,000 miles it now has 220,000 miles. It has always had a rough & low idle (525 RPM) when hot. Truck runs great before it warms up. The hotter the engine temp the worse it runs. Finally got tired of smelling the fumes and took it to Ford. They have told me # 7 injector is bad and the others are weak. Could that be right or could something else be wrong? Why does it run smooth before its hot? Any information would be appreciated.
Thanks,
John
Old 02-04-2007, 10:32 PM
ForemanES's Avatar
ForemanES
ForemanES is offline
I bet you the rough idle problem is a simple IPR o-ring leak. But with 220,000 miles your injectors may be getting a little tired. I have been told at on average ~150,000 miles they need rebuilt. I replaced my original injectors with 250,000 miles on them with some new ones, but they were still working fine.
Old 02-05-2007, 06:36 AM
Weedeater's Avatar
Weedeater
What is a IPR o-ring and where would that be?
Thanks for the information.
John
Old 02-05-2007, 07:01 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Foremans's right (usually is) IPR orings will cause those symtoms.
Not to hard to do:
http://cw-diesel.com/LuxSite/IPRInfo.htm
Rachel Nikki Wilson
1997 - 2003 F150
06-14-2014 12:09 PM
DItR
06-30-2013 07:01 PM
palomartian
10-02-2009 10:53 AM
BlackJeep
13
11-23-2008 01:17 PM
jetheridge
06-01-2001 04:11 PM
Quick Reply: injector problems?
