Factory engine block heater question..
My 1998 F-150 has a factory engine block heater. I plugged it in last night ( was -5 F here in michigan ) and I went to check on it this morning and noticed no difference between a true cold start and with a block heater in use. Is there any easy way to check if its working? Is it supposed to show a light on the cluster when in use? Is it supposed to maintain temperature enough to register on the temperature gauge? Any info you can provide would be immensely helpful. Thanks all!
Well, I went to a friends house this morning (-1 for a temp). He had his truck plugged in all night. I felt the block and there really was a difference in the temp of the block compared to the temp of the air. So, I guess that I would have to disagree with the statement that "It doesn't get THAT warm". If it is a heater...there will be a difference in temp between the block and the temp of the air. Joe
the heater in my 97 from factory is a 600 watt heater.its not enough to heat the hole cooling system but will keep it warm enough to start.and the are in 1 of the freeze plugs in the water jacket.i put one on each side and it will move the gauge a little.on my old 75 f250 with a 360 i put 2 1200 watt heaters and it will open the thermastat up.instant heat this way.cost around $60 but worth every dollar
I have the same truck with the 4.6. Mine is factory installed, it is where a frost plug would be in the block. Mine is absolutely silent, but you will know if it is working if it spins easily. My truck sat outside from friday night until this monday morning, it never got above zero (Minnesota) At 5:00 this morning I plugged it in and at 8:30 I started it up. Started like it was 40-50 degrees out when the air temp was-24 below. No strange noises, just turn the key and it's running, Sooooooooo much easier on the battery, starter, everything. Within 5 minutes it was starting to blow warm air and the temp gauge was rising. By far the best block heater-engine combo I have ever had. 3 to 4 hours seems to be more than enough time even in the -20-30 below range. I got sick of all the cheap timers not holding up so now I trip the ground fault in the one bathroom which also controls the outside outlets. I plug it in the night b-4 then at 5:00 when I get up I reset the ground fault, which starts the heater. I have a lighted end on the female end of the extension plug so I can look out and confirm that it's a "go". I go out 8:00-8:30, fires right up. Hope you get yours fixed, really is great when working.
spotty
spotty
dlpinkc
01-08-2004 10:28 PM
