EGR tube repair - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
EGR tube repair
Old 02-04-2007, 03:39 PM
lugnut05's Avatar
lugnut05 lugnut05 is offline
lugnut05 is starting off with a positive reputation.
EGR tube repair
I tried this repair on my EGR heat tube and it worked like a champ.
It also saved me the $150.00 Ford wanted for the replacement part.
Like most it was broken off at the exhaust manifold.
I removed the upper flare fitting at the intake plenum, and measured the ID of the tubing. It was .550 ".
I found a piece of 1/2" (.500") O.D. copper tubing ( it would be considered 3/8" copper pipe ) and cut it to about a 2" length.
I then expanded the ID using a tapered drift so that it's O.D. measured .545".
I inserted the copper tube into the heat tube and then the whole assy back into the manifold. It should go right together and be an interference fit.
Re-install the top fitting into the plenum and you're good to go !
Super quick 300 Six Choke heat tube question Joeblowv1 Ford Inline Six, 200, 250, 4.9L / 300 1 05-06-2016 07:23 PM
Choke stove/heater tube repair 84 e350 Dago Red Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 05-06-2016 02:50 PM
Copper brake lines? wheelieking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-05-2015 12:20 PM
What size tubing are my brake lines? freightdogfred 1987 - 1996 F150 & Larger F-Series Trucks 15 12-06-2008 07:49 AM
Air Injection tube missing on CAT converter rwsam 1987 - 1996 F150 & Larger F-Series Trucks 3 01-26-2005 05:11 PM
Tags
150, 46, egr, exhaust, expedition, f150, f250, fix, ford, manifold, pipe, ranger, repair, repairing, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
