Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-04-2007, 04:28 PM
annemarie51101 is starting off with a positive reputation.
1986 Ford E150 - no start
We have a 1986 Ford E150 van. Not starting. Any idea where the intertia switch and fuel relay may be located so that we can check them out. Thanks!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-04-2007, 05:05 PM
Mil1ion is starting off with a positive reputation.
IIRC, The Inertia switch was usually under the dash
The fuel relay ?
I know the computer performs a "ground out" to actuate the fuel pump.
maybe check the autozone site repair section for a diagram ?
  #3 (permalink)
Old 02-04-2007, 05:55 PM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
You are getting spark correct? Remember the fuel pump will not cut on if there are no signals from the distributor. Here's a link to the repair guides.
http://www.autozone.com/servlet/UiBr...pair_guide.jsp
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 02-05-2007, 02:28 PM
subford's Avatar
subford has a very good reputation on FTE.subford has a very good reputation on FTE.subford has a very good reputation on FTE.
Note the computer will close the relay for one second when you turn on the key and then as Franklin2 said it will not come on again until it gets a PIP train from the Distributor.
As Mil1ion said the fuel cutoff switch should be on the toe board on the passenger side or behind the passenger kick panel.
The relay should be mounted to the passenger fender right beside the EEC Power relay.
Here is a diagram of the electrical fuel system.
http://i54.photobucket.com/albums/g91/subford/Fuel/1987FuelpumpselE1505.gif
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
